RINRIN
Wheel Alignment
RINRIN
In my country I believe that the wheel alingment is a huge mess. The technicians make rough adjustments and if they use the PC the info in the PC is not relevant. :)
There is no info in Haynes repair manual
The below info is in Haynes Workshop manual
Toe in 1.0 -- 3.0 mm
Caster 1.20 --2.20 degree
Camber -30 -- 30 degree
King pim inc 9 -- 10 degree
and it mentiones that these values are for standart height.
But in Haynes Data Book
Toe in 1.0 mm
Caster 2.20 --2.80 degree
Camber -30 -- 30 ddegree
King pim inc 9.70 -- 10.30 degree
Which of these values are correct? My riding height is not standart. I have 3.5 mm springs.
Which values I should use for my pug :blush:
Personally, I always set the tracking for 0 degrees - ie parallel.
AndyJ
Mine's lowered ~35mm with +3deg toe in...the rest of the values are just however it sits...no obvious problems
Cloverleaf
Less toe in (i.e. more toe out) will make it sharper to turn in, hence it would be more twitchy on a bumpy road. I'd say settings depend on personal preference and car usage.
cir287
if its for the road I would do as Anthony says - straight ahead
RINRIN
I dont believe this is that easy. Cornering and bumping the road effects, fuel consp. and tyre life related to these issues. I will set to the setup in the workshop manual.
chris1986
i have always set mine to toe in 1mm, no probs.
