Guest Ian King
205 Gti V6
Guest Ian King
Well i hve project and so many plans for it. 1st of all i got hold of a 205 with an genuine dimma kit fitted. that was the only part i had no questions about doing, i just love the kits. my main problem idea wise is the engine, what engine what size.
1st of all im thinking about putting the 3.0 v6 from a 406 in. The main thing about this is will it fit? I can get hold of a full car so thats not problem,
How much modifiction is required to get the engine in? ive looked at a few pictures and the mounts look resonably similar. if i use the 406 hubs and shafts will this suffice?
I was just going to put a 1.9 gti engine in but good ones are gettin hard to find now, 2 ive bought have turned out to be frankenstein creations, 1.6 b2c block 1.9 gti head.
So do the v6 engine fit without spaceframing the front end? ive seen the twin v6 monster oon this forum but hvnt got the time to go into that much structural modification as tht one.
Any help on this would be appriciated.
Ian
Goliath
It will fit but it needs a lot of work.
Custom top mount
Extensively modified subframe and lower mount
Custom clutch mechanism
Modified Rad setup
Shortened driveshafts (you cant use the 406 ones in standard length)
Loads of smaller things too, it is possible but really not your run-of-the-mill engine conversion.
p.s. You say your 205 has a genuine dimma kit, how come your Signature says its a replca? :wub:
Guest Ian King
was my old 205 i got hold of sum1 else cos the replic kit fitted like a bag of scrap and looked just as bad.
Guest Ian King
with the shaft problem, would you not be able to use the arms and hubs i need a wider track to fill the dimma arches or are they too much wider?
Goliath
You will need adjustabe top mouts if you were to otherwise you will just have waaaay to much camber.
Normally dimma arches are filled by different offset wheels or spacers and not by wider track as such.
Guest Ian King
http://www.kad-uk.com/peugeotparts.htm 3rd item down. i was plannin on gettin these in the 1st place. for the wider front i was looking into wider track due to the fact i dont trust spacers at all i have a few sets of alloys but none hve wide offset or are deep dish like the dimma spits. just over an inch short width wise.
Edited by Ian King
Goliath
They might well do but to be honest I know bugger all about adjjustable top mounts and which ones to go for.
Guest Ian King
well ive decided to pluck up the courage and get this project started. will be a long project so wont be posting pics often, my garage is flat out so cant find the time to gt my car in =(.
List of things to do
buy a 406 v6 car
find custom mounts
modify subrame
seam weld front end of car
strut braces front rear
custom exhaust
mappable ecu
Cage?
oh and paint the car!
hopefully thats it, most of bits will be from the 406 (brakes, bottom arms, hubs, shafts, as ill be buying a full car.
when i get around to starting it propeerly ill start posting pics ect. in the mean tim wish me luck!
Edited by Ian King
