kyepan 291 Posted February 6, 2009 Hi there, Are there any engine building books that are a must read? I have bought "high performance short block 4 cylinder" and another one, from the first few pages i've read in the introduction, it would seem, building engines is mostly about measuring twice, and test building to double check. but wondered if there were any others that were essential to the novice wanting to understand the engineering and tolerances properly? Also does haynes contain the sufficient clearance information to blueprint a rebuild of a 1.9MI, or is there a more detailed workshop manual available [found this now] ps, have done a search and not found an awful lot cheers J Share this post Link to post Share on other sites
yanto 0 Posted February 7, 2009 Hi there, Are there any engine building books that are a must read? I have bought "high performance short block 4 cylinder" and another one, from the first few pages i've read in the introduction, it would seem, building engines is mostly about measuring twice, and test building to double check. but wondered if there were any others that were essential to the novice wanting to understand the engineering and tolerances properly? Also does haynes contain the sufficient clearance information to blueprint a rebuild of a 1.9MI, or is there a more detailed workshop manual available [found this now] ps, have done a search and not found an awful lot cheers J I'd like to know that too-got a haynes but would like somethin more detailed bout engines and how to rebuild start to finsh. Share this post Link to post Share on other sites
