Guest Wheres_my_wig
Gti-6 Front Brake Conversion
Guest Wheres_my_wig
Quick question, Im going for the GTI6 front brake conversion, with gti6 master cylinder and keeping the rears standard with new disks and pads... also looking at getting a set of braided hoses. Are the kits for the 205 gti 1.9 going to fit the gti6 calipers or vice versa. Im just not sure which ones to go for. any idea would be welcome. Great threads on all this by the way!!
Peetypug
they wont fit the fronts as they will be too short iirc.
Miles does longer ones and they are very good.
Andy F
Speak to miles
im sure he sell a set suitable for the 205 to fit the 306 gti-6 calipers
Spiky
or just make your own :)
they easy to make
Rock Lobster
You need any special tools to make your own? Didn't realise there was a diy option!
Spiky
nope
some 11-13 brake spanners (normal ones will do the job though)
think blade on an angle grinder, or a VERY sharp metal chisel (hammed for chisel too)
masking tape (to wrap the braid before cutting stops fraying)
tiny screw drvier or bradol to open up braid
thats it i think :)
Rock Lobster
This is good news! Will definately give this a go as i need custom legths so off the shelf kits will be no good. Can anyone reccommend somewhere cheap to get all the neccercary bits and bobs from?
cheers, your help is appreciated!!
Spiky
Rally Design Edited by Spiky
Rom
How much further do the Gti 6 calipers sit ?
My hoses fit fine with 307 Hdi calipers.
mrswampy
I can also supply not only standerd sets of braided hoses
along with custom made ones
all at very good prices along with excelant quality.
Mikey S
are the braided 1.9 gti hoses shorter than the original rubber ones then? as i have fitted '6' brakes on my laser with standard 1.9 hoses and not had any problems with them :blush:
mrswampy
No the braided standerd lines are the same length
the normal hose will fit and do the job
but
upon extremes of steering and or suspension travel the hose may get pulled or stretchd which in extreme cases cause failure of the hose
this may also if pickd up on lead to an mot failure
Mikey S
but
mine certainly arent stretched to the extreme on full lock or on maximum suspension droop, there still quite plyable, and im an mot tester.
I cannot recall the HDI caliper from memory but it's not far off the Gti6 one, I know there's not allot in it so the little extra length makes a huge differance but then again aftermarket std hoses might be different too knowing what there like,
Having seen the GTi6 one's on std hoses it does give a slight bend on full lock on full droop not something I'd be happy with and hence why any converted car I fit these 2 get's these pipe's, May sound like a sales pitch but for the money it's hardly making me anything
mrswampy
As miles says
id rather spend or advise you spend a few quid to do the job correctly than run the risk of a brake hose failure
