jamesb 0 Posted January 26, 2009 Ive just been out for a drive in the pug & when the engine gets warm (about 10 to 15mins into my journey) i noticed it started to tap quite loudly. It dosent seem any better or worse throughout the rev range but obviously taps slower when the revs reduce. Im using 10/40 oil, should this be ok or should i be using something else? The engine has 90k ish miles on it & has been serviced regularly throughout its life. If its the tappets can they be adjusted or will i need to replace them? Cheers guys. Share this post Link to post Share on other sites
DamirGTI 367 Posted January 26, 2009 Id look for cracks on the exhaust manifold first , so either cracked ex. manifold or blowing from manifold to downpipe joint (mesh ring) or blowing from the manifold to head gaskets .. if all of those areas are sound , then check/measure the valve clearances .. Damir Share this post Link to post Share on other sites
