wardy18
Stud Conversion
wardy18
Damn I just had a thought, I've sorted out and ordered the studs and the relevant nuts for the revolutions but not any nuts for my wets which also get me too an from an event, Damn it
EdCherry
Better buy some nuts for them too!
Personally if I was going to buy a rattle gun, buy a good one! Might be worth your while going on eBay and buying a second hand snapon 24v jobbie, might be expensive but will last and can be serviced/repaired by snap on.
wardy18
do they do a cordless battery one
wardy18
i need some Flat Faced M12x1.5mm nuts, anyone got any?!
Not spares but try people such as rallydesigns, Demon Tweeks, Peterlloydrallying (sp) or Miles from on here, one of them should be able to supply you with some SN61 nuts.
I'd still use a torque wrench to check tighten the nuts when you've done them up with the buzz gun but I'd undo them a turn from tight with the buzz gun before using the torque wrench just to be sure they aren't already over tightened.
