Ajr 0 Posted January 14, 2009 I appologise for bringing up this subject that has no doubt been covered before. Unfortunately my 205 doesn't live with me so i can't go and look at it, and i'm off to the scrap yard to get some bumpers for it at the weekend. First things first, mine's a ph1 or 1.5(E reg, ph1 rear lights, updated dash though by looks of it) Are all GTi bumper trims universal? The car at crawley scrappers is a K reg so very new in comparison. Now i am awaiting my mate to sort the haynes manual, but from what i've gathered: Front bumper held on by two bolts, one on each side under the arch where the wing bolts to a bracket sticking out of the chassis leg, same as a peugeot 106? There is a captive nut or a thread in the bumper which rusts and seizes, the trim strip needs to be removed to get to the back to drill it out. How does one remove the front bumper trim strip? The rear bumper is held on by some 13mm nuts inside the boot and a few more under the arches same as the front? I don't want or need to remove valances. Is there anything i'm missing? And can i fit the k reg bumpers? Many thanks for any help, i did use the search function but didn't find any really conclusive answers. Alex Share this post Link to post Share on other sites
welshpug 1,626 Posted January 14, 2009 (edited) the P2 trim is identical bar the colour, its a very dark anthracite near black rather than grey. same as the front, there are 13mm nuts in the wheelarches as well as the 2 13's in the boot, also there is a screw vertically in the bumper above the number plate, usually rounds off as its so rusty. If the large posi screw is rounded/rusty, remove the number plate and you can access the 2 13mm nuts that secure the bracket to the body via 2 holes. Edited January 14, 2009 by welshpug Share this post Link to post Share on other sites
Ajr 0 Posted January 14, 2009 Ah, that explains why my front and rear bumpers are practically white now they've faded then! Will be painting it all when i respray the car anyway so it's all good. As for removing it, am i heading in the right direction? Share this post Link to post Share on other sites
