dino20vt
Axle/beam Questions For A Change.
dino20vt
Firstly, am I right in thinking a base model 309 has:
Drums
Different trailing arms (especially when compared to a gti arount the ARB area)
Different stub axles
Thinner or no ARB
Thinner TB's.
The reason I ask is I have a 309 gti axle with one seized arm and a good base model 309 beam.
Best case (but I doubt) the beams are identical other the TB's, brakes and ARB and just swap that lot over.
Worst case the arms are different, and my GTI shafts are 'shafted'!
If so can I put base model shafts onto gti arms then put that lot into a base model tube?
Is it easy swapping shafts?
Cheers in advance.
yep, pretty much correct on all counts, I think the arms in general are the same, bar possible differences in the geometry.
Cheers in advance.
Yes, if you have access to a press :wacko:
Edited by welshpug
dino20vt
Other than the silly drums the main difference I noticed was on a gti theres a small dust cap (size of a penny) which when removed gives access to the ARB, the base model unit has in its place something resembling a hub nut dust cap (big) which looks like it possibly isnt removable. So will it have an ARB?
Edited by dino20vt
not quite sure what you mean without a picture!
dino20vt
True! Tried taking one earlier but it was too dark!
Ricardo
Think he means the cap in the arm where an ARB plate usually goes on the 205s. about the size of a hub bearing cap!?
Hi Dino u got it back OK then?
Richard
dino20vt
Yea Richard, cheers mate!
If the base model beam has no ARB, then it will have a plastic cover in its place - this is removeable and simply taps out.
If you've got a "good" (read - serviceable tube and two good shafts) then you have the main bits you need to repair your 309 GTi beam. Obviously you'll need bearings and seals from Peugeot if you're going to replace them at the same time - and frankly it would be extremely foolish not to.
dino20vt
So basically, a 1.1 beam is the same other than the brakes, stub axle, tb's and arb. All I need to do is swap the above and i'll have a gti beam?
I think there's something up with your computer Dino :lol:
in answer to your question though, yes indeed :)
dino20vt
I think there's something up with your computer Dino ;)
I was on the internet on my phone, hence the repetition!!
Nice one, i'll get some pictures up at the weekend so people can see what I mean by the differences in the ARB access area.
dino20vt
Heres what I mean
ahhh right, just a blanking cover and no ARB :)
dino20vt
So all being well, prise the cover over and shove the GTI ARB in, job done, in a nut shell!!
