johnnyp
Base Model Calipers
johnnyp
i rang gsf to order a pair of calipers for a tu engined 1.0 xe i know they are bendix but he said there was 2 types and they changed over in about 1990 i didnt think there was a difference i the bendix caliper then he said he could only get the latter ones and i needed the early verision. Can i just get the latter model and use them
thankyou Johnny
I'd like to know what the difference is between the early & later ones.
The only way I can think of two types is vented & solid but surely he hasn't got that confused?
You should be Ok getting the later ones imo.
johnnyp
i was confused as well i thought there was just one type for solid discs
Thanks Johnny
GTI6BOY
might be a 2mm increase in piston size
Edited by GTI6BOY
Not according to Brakeparts.co.uk.
The only change I can see is they stopped using the Girling solid disc caliper (which are listed as rare) around then & just fitted Bendix afaik. They still had the same sized 48mm piston though.
