hexhamstu 9 Posted December 10, 2008 cheapest place to get a full rebuild kit and some ARP bolts? got a spare mi16 engine so thought i may aswell rebuild it. Share this post Link to post Share on other sites
DrSarty 90 1 Cars Posted December 10, 2008 I suspect you can cobble most if not everything together off here my friend. Good luck and lucky bastard just having an Mi lying around to play with. Good on ya too. Sarty Share this post Link to post Share on other sites
hexhamstu 9 Posted December 10, 2008 (edited) I suspect you can cobble most if not everything together off here my friend. Good luck and lucky bastard just having an Mi lying around to play with. Good on ya too. Sarty i think with a new head it would run fine, but i dont have a car to put it in so whats the fun in that? Edited December 10, 2008 by hexhamstu Share this post Link to post Share on other sites
DanteICE 72 Posted December 10, 2008 I am looking to rebuild an Mi16 engine also, do we know what parts will be best to be replaced? Geoff Share this post Link to post Share on other sites
hexhamstu 9 Posted December 10, 2008 (edited) I am looking to rebuild an Mi16 engine also, do we know what parts will be best to be replaced? Geoff good question a definitive list would be good, never done any of this before. guess i will need a smalled torque rench as mine is massive. i have this s*itty argos one http://www.argos.co.uk/static/Product/part...xt%3ETORQUE.htm Edited December 10, 2008 by hexhamstu Share this post Link to post Share on other sites
Baz 421 Posted December 10, 2008 Last time i bought the majority of parts from a local motor factor, all the gasket sets, seals, head bolts etc etc. In fact i still have one set left, not sure i'm going to use it anytime soon either, i'd happily sell for a fair figure. Share this post Link to post Share on other sites
welshpug 1,629 Posted December 10, 2008 (edited) you're best off stripping it down before buying any parts, you never know what you're going to need, but at a minimum a set of shells (about £50 at a vauge guess) Gasket set, top and bottom end, should contain pretty much anything you need, then add headbolts, water pump, timing belt kit. worst case would be you'd need a set of liners and pistons additionally to the above. and paint if you're a tart a 3/8 drive torque wrench is a good addition if you're not sure about just tightening stuff by feel, a 1/2" drive one for the head bolts, and an angle tightening gauge, feeler gauges to check the liner protrusion, plastigauge for checking the bearing tolerances. Edited December 10, 2008 by welshpug Share this post Link to post Share on other sites
Anthony 1,000 Posted December 10, 2008 Not to mention a set of flywheel bolts eh? Share this post Link to post Share on other sites
dcc 855 Posted December 10, 2008 Ive just basically rebuilt a mi16. Bores honed new piston rings new shells new cams (more for performance really) gaskets clutch headbolts stuff like sand paper, RTV, oil, antifreeze... All came to about £200. Share this post Link to post Share on other sites
Baz 421 Posted December 10, 2008 Did you steal most of the parts then? A decent comprehensive top & bottom end gasket & seal set would be lots more than that alone... Share this post Link to post Share on other sites
welshpug 1,629 Posted December 10, 2008 Not to mention a set of flywheel bolts eh? indeed! for a tenner its not worth skimping on those, especially as everywhere I've checked up does state to renew them there's a GSF in Swansea Stu, and bassets Citroen are really helpful Share this post Link to post Share on other sites
dcc 855 Posted December 10, 2008 the only thing that isnt really including there is the cost of the cams i guess! Share this post Link to post Share on other sites
hexhamstu 9 Posted December 10, 2008 the piston did touch the valves and has a slight mark on the top of it, would it be wise to replace this? Share this post Link to post Share on other sites
Tom Fenton 1,529 Posted December 10, 2008 Set of main bearings, set of big end bearings, set of thrust washers, comes to about £105, they are more than you think. Piston rings if you're feeling keen are about £75 Bottom end gasket set is a waste of money IMO, there aren't any really. The only ones you want are the crank seals either end, and the hockey stick seals that fit down the sides of the end main bearing cap. Crank seals can be got from GSF, hockey sticks are main dealer and not dear. Genuine big end bolts are not expensive from Peugeot, about £40 the set. Share this post Link to post Share on other sites
welshpug 1,629 Posted December 10, 2008 I thought the liner seals came in the bottom end set? Share this post Link to post Share on other sites
Tom Fenton 1,529 Posted December 10, 2008 I never disturb the liners if I can help it, I've seen too many scrap blocks where the seats have corroded away and they will never seal again. Leave the buggers clamped in is my choice. Share this post Link to post Share on other sites
DanteICE 72 Posted December 11, 2008 Go on Baz whats there? And before you all say, you can see.....yes I can but its good to hear the owner tell us! Geoff Share this post Link to post Share on other sites
welshpug 1,629 Posted December 11, 2008 where from Baz? Share this post Link to post Share on other sites
Baz 421 Posted December 11, 2008 Selected from a few different motor factors, i've had those lot a fair while now as i bought 3 complete rebuild sets at the time. Payen headbolts, head & bottom end sets, inc all gaskets (inc headgasket!) & seals, AE Piston ring set, thrust washers, main and big-end shells, Gates Powergrip belt & Tensionner Kit Share this post Link to post Share on other sites
