WooDooUK 1 Posted November 24, 2008 Hi, After heavy rain i can always hear water sloshing about in the drivers side sill, it is more than likley just a blocked drainage hole, However its not obvios (to me anyway ) were the hole is. Can anyone point me in the right direction? Cheers, Share this post Link to post Share on other sites
skeggyrik 3 Posted November 24, 2008 In the bottom of each sill there are weep holes and they get blocked up, there was a thread about this a while back , some people got pints and pints out of theirs after a quick broggle in the hole to unblock it. If you look along the "seam" on the bottom on the sill you will see the the lightly wider section this "slot" gets blocked up with crap and the sill can fill with water. You may have to jack the rear of the car up up to get it all out if remember what others said in that post I referred to. Share this post Link to post Share on other sites
Ryan 99 Posted November 24, 2008 There are also a couple of rubber bungs in the bottom of each sill. They have an X-shaped cut in them, and you can push you finger through them to drain the water out. I pulled the bungs out, as the normal smaller drain holes were all blocked with underseal. Check the rear window seals, as this is usually where the water gets in in the first place. Share this post Link to post Share on other sites
joe1joe 3 Posted November 24, 2008 yep i had this problem........ looked as tho som of the holes had been blocked with sealer from factory??? i jst driled them out, and am gona now put som treatment in the seals ... Share this post Link to post Share on other sites
DamirGTI 329 Posted November 24, 2008 Are you sure that this sloshing sound comes from the sills ? i've had the same kind of sound and it was water trapped inside the passenger doors .. so i cleaned up the drain passages on the bottom of the doors and i also drilled two little holes on each corner just to be sure that all the water drains out during monsoon rains .. and it's been fine since then .. Damir Share this post Link to post Share on other sites
Henry Yorke 269 3 Cars Posted November 24, 2008 (edited) Double check it is not in your footwell too. I have had this happen on a mates 406 and my 306 DTurbo. I couldn't locate the drain hole so I just made a new small one! Edited November 24, 2008 by Henry Yorke Share this post Link to post Share on other sites
bren_1.3 1 Posted November 24, 2008 get it out pronto. my e-reg drivers side sill needed welding up quite substancially after being brimmed with water for a few years. Share this post Link to post Share on other sites
joe1joe 3 Posted November 25, 2008 my car was def in the sills....ALOT came out Share this post Link to post Share on other sites
mr_exe 1 Posted November 26, 2008 We've got this with the XS we've just acquired, but i've made a new drain hole with my finger Share this post Link to post Share on other sites
SurGie 54 Posted March 29, 2009 In the bottom of each sill there are weep holes and they get blocked up, there was a thread about this a while back , some people got pints and pints out of theirs after a quick broggle in the hole to unblock it. If you look along the "seam" on the bottom on the sill you will see the the lightly wider section this "slot" gets blocked up with crap and the sill can fill with water. You may have to jack the rear of the car up up to get it all out if remember what others said in that post I referred to. Here it is mate. Share this post Link to post Share on other sites
stutto 0 Posted August 6, 2009 Bump because of the weather we've had recently - check yours if you have not done so recently. I thought I heard water in the sill last night as I left work and sure enough the rear two drainage points were solid with sealant/paint. Upon breaching the blockage with a penknife water trickled out for a good couple of minutes. Share this post Link to post Share on other sites
Pob 1 Posted August 6, 2009 (edited) There are also a couple of rubber bungs in the bottom of each sill. They have an X-shaped cut in them, and you can push you finger through them to drain the water out. I pulled the bungs out, as the normal smaller drain holes were all blocked with underseal. Check the rear window seals, as this is usually where the water gets in in the first place. I've done this on mine... I had alot of water in my sills pulled the plugs out and alot of water came out, I've also left them out. Still don't know where the water was/is getting in. I fitted new window seals and pretty sure it still gets in somehow. Dan Edited August 6, 2009 by Pob Share this post Link to post Share on other sites
