Guest dan_222 Posted November 17, 2008 i test drove a 1.6 gti with 110k last weekend. i have never drove one before. when i went to take of it starts to judder like i was to quick with the clutch and not enough revs but this happend all the time and also happend when moving and trying just to give it a little bit of power. is this a common problem? and what should i look at to solve it? Share this post Link to post Share on other sites
hexhamstu 9 Posted November 17, 2008 its a common problem many possible causes, search for kangarooing or juddering Share this post Link to post Share on other sites
Mikey S 29 1 Cars Posted November 17, 2008 dan_222 said: i test drove a 1.6 gti with 110k last weekend. i have never drove one before. when i went to take of it starts to judder like i was to quick with the clutch and not enough revs but this happend all the time and also happend when moving and trying just to give it a little bit of power. is this a common problem? and what should i look at to solve it? i would look at the igntion system as it sounds like something is breaking down as load is applied to the engine. it maybe that you have a a defective pluglead that is arcing to earth when pressure is applied. i always try a squirt of wd40 down the end of the plug lead to insulate it then try driving again to see if its cured it. tbh, for the price of a distributor cap and rotor arm, plug leads and spark plugs you may as well change the lot then get the ignition timing checked and adjusted then a fuel mixture tune. it will make for a much nicer driving car. hth mike Share this post Link to post Share on other sites
djinuk 2 Posted November 17, 2008 there is a very good chance its only somthing simple.. simply play on the fact that it could be somthing serious , and get the price knocked dwn.. then replace the igntion comps.. lastly being the igntion amp and coil (mine was the coil that played up) Share this post Link to post Share on other sites
Guest dan_222 Posted November 18, 2008 thanks for the replys. i will look into possible fixs Share this post Link to post Share on other sites
