NOsMAN 11 1 Cars Posted October 13, 2008 (edited) O.K. the problem is the autobox wont let me rev past 3000rpm before automatically changing up(approaches 3000rpm then jumps up a gear) ...Only way to rev the engine is shifting manually .. Whats causing it and whats the remedy ? Cheers Edited October 13, 2008 by NOsMAN Share this post Link to post Share on other sites
cybernck 403 1 Cars Posted October 14, 2008 it does that on full throttle too? Share this post Link to post Share on other sites
NOsMAN 11 1 Cars Posted October 14, 2008 (edited) yep it still does it on full throttle. asked 2 different pug specialist and they said they know bugger all about the autoboxes Edited October 14, 2008 by NOsMAN Share this post Link to post Share on other sites
johny105_y2k 1 Posted October 14, 2008 unaware of the 205 setup , but working with auto's i'd check the load sender (if there is one fitted) if there is it'll be somewhere on the throttle side Share this post Link to post Share on other sites
johno_78 2 Posted October 14, 2008 Is the kickdown cable still connected? Share this post Link to post Share on other sites
NOsMAN 11 1 Cars Posted October 14, 2008 unaware of the 205 setup , but working with auto's i'd check the load sender (if there is one fitted) if there is it'll be somewhere on the throttle side Just spoke to an Auto box specialist and he mentioned the same thing or the wiring from it .. Is the kickdown cable still connected ? Its still connected cos it still kicks down but like i said as soon as it reaches 3000rpm it changes up Share this post Link to post Share on other sites
Miles 331 1 Cars Posted October 14, 2008 There's only the start inhibit wiring on the box and nothing else, it's well let's say very basic, The kickdown Cable you should feel under your foot but the gear's should go past that point anyway, Thats about my knowledge of Auto boxes. Share this post Link to post Share on other sites
steve@cornwall 100 Posted October 14, 2008 Only thing I know about auto boxes is that they misbehave with low oil - and the oil level should only be checked when hot after a lengthy run. apparently if the level is correct at cold, there's nowhere near enough. (alegedly) Share this post Link to post Share on other sites
NOsMAN 11 1 Cars Posted October 15, 2008 O.K managed to take a look at it today with the help of the local pug dealer (J.Harrison) who said the cable is a bit slack at the throttle and told me to adjust it . Turned it as tight as possible and its made a huge difference but its still too slack in my opinion .Now revs upto 4500rpm in kick down so overtaking is easier but could be improved . Share this post Link to post Share on other sites
