johny105_y2k 1 Posted October 9, 2008 (edited) Morning all., the mrs car failed yester day on emisions. the tester said - "its had a centre section and it looks as though the sealant has dropped inside if i was you i'd take it off and clean it up and re-seal it then it'll most likely go through. you wont need a lambda" true it has had a centre section, but why would taking it off and re-sealing would it bring the emisions down? i cant get my head round it. the lambda is on the downpipe any suggestions?? johny its a 1.1 tu Edited October 9, 2008 by johny105_y2k Share this post Link to post Share on other sites
welshpug 1,677 Posted October 9, 2008 if its leaking exhaust gases pre-cat the emissions results will be out. Share this post Link to post Share on other sites
johny105_y2k 1 Posted October 9, 2008 there's no blow there though. . . . Share this post Link to post Share on other sites
RossD 44 Posted October 9, 2008 (edited) What were the emissions from the test? By the sounds of it the Lambda was out of range because of the leak in the exhaust, so the tailpipe sniffer was reading artificially weak. (Even though the Lambda on the car is fine) Remember, CAT cars can fail for the emissions being weak (IE Lambda out of range high or low) EDIT: Just re-read, no exhaust leak.... Need the actual results to comment further then Edited October 9, 2008 by RossD Share this post Link to post Share on other sites
johny105_y2k 1 Posted October 11, 2008 well i've been doing the other jobs on the vehicle and have found the tester to be incredably petty. but the computers were down so i haven't got a exhaust print out .but having looked at the back box joint to the centre section its all covered in soot but there is no audible blow so i'm going to clean it up and see.... if not i'll make sure i get a printout thanks johny What were the emissions from the test? By the sounds of it the Lambda was out of range because of the leak in the exhaust, so the tailpipe sniffer was reading artificially weak. (Even though the Lambda on the car is fine) Remember, CAT cars can fail for the emissions being weak (IE Lambda out of range high or low) EDIT: Just re-read, no exhaust leak.... Need the actual results to comment further then Share this post Link to post Share on other sites
