Tesstuff
Engine Question
Tesstuff
The AA man finally cured my 'click click click start' problems by noticing that the battery terminal was barely making contact, so my question is this :-
If the battery being loose like that makes starting problematic, will it also affect anything else to do with the engine?
Like fuel consumption or performance?
I know it sounds stupid, but i never imagined a loose terminal could have affected my starting so much so i wouldnt be at all shocked to hear it would have affected other things.
Which terminal, positive or negative?
A loose (positive or negative) terminal can have a big effect on starting but imo once its up & running then a loose positive terminal will make very little difference to the performance or ecomony of your car & so will a loose negative terminal but the loose negative terminal could cause sudden power loss due to engine movement if it is loose on the gearbox stud.
GRaham.
