gazzer 1 Posted October 7, 2008 changed clutch on 2ltr 16v with after market one from euro parts, but now its very noisey, so i put old pressure plate back on but still noisey when pulling hard, anyone know why? Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted October 8, 2008 Did you change the release bearing? Could be the input shaft bearing in the gearbox. Graham. Share this post Link to post Share on other sites
welshpug 1,678 Posted October 8, 2008 did you re-fill the box oil? Share this post Link to post Share on other sites
gazzer 1 Posted October 8, 2008 did you re-fill the box oil? refilled oil, and tried to pressure plates, old and new, at speed the noise goes off as it not under a lot of pressure. the grinding noise is mainly in first and second gear so might be input shaft as said Share this post Link to post Share on other sites
gazzer 1 Posted October 10, 2008 noise really bad now, sounds like the release bearing is ratting or grinding but the clutch works fine. just wish i knew whATS WRONG. GOING TO take gearbox out again tomorrow to find out why, i also have an old 1.9 gti box so i might put that on . Share this post Link to post Share on other sites
ablister 31 Posted October 10, 2008 friction plate on right way round? Share this post Link to post Share on other sites
Jrod 7 Posted October 11, 2008 Input shaft bearings? Share this post Link to post Share on other sites
gazzer 1 Posted October 12, 2008 turn out the gearbox was knackerd, the input shaft grinded and jammed when turned by hand. cost me £85 for new gearbox. Share this post Link to post Share on other sites
