Jean_quemener
Phase 1- 2 Dash Swap?
Jean_quemener
I have a mate who is wondering if the swaping the dash from phase 1 to 2 straight foward, his phase 1 dash is nackered and he would rather have a phase 2 dash, can this be a straight swap of is there alot of fiddeling about to be done, any input would be grate
thanks jean
You will need the complete heater assy as well, Other parts I'm just guessing arre different as I know they are on the 309 is the steering coloum and a couple of the mounting bracket's, but all this is easy to sort.
EnglishRob
thanks jean
*shudders*
I did one of these a couple of years back the hard way. What I'd recommend is trying to get the wiring loom out of a Phase 2 car as well as the looms on a Phase 1 and Phase 1.5/2 car are different (I managed to match most of it up over two weeks reading through Haynes manuals but didn't manage it 100%).
Good luck, not something I'd want to attempt again myself but I guess it can't be any harder than fitting a 206 dash in a 205.
Rob
chris-stdt
Does anybody have anything more to add on this as ive been offerd to swap my 406 for a phase 1gti and parts of the dash are missing + i dont like the phase 1 dash tbh
Wouldnt have to be a phase 2 just which ever is easiest to swap over / get hold of
Any info would be greatly apprieciated
pugit666
i did this swap a couple of years ago although i left the indicator stalks as phase 1. the only problems i had was the heater. you need a wiring diagram for both models as there is an extra wire on one of them. If you can follow a wiring diagram you'll have no bother. the bonnet release handle doesn't really fit either so unless you change that too, it will just have to dangle down the side of the dash
chris-stdt
Thanks for the reply but the lad came round with the car today and the sills were rotten so i kindly suggested he took it away again :rolleyes:
