Tommer 0 Posted September 1, 2008 hey gang! finally got my 309 gti rear beam on over the weekend and it does look and feel sweet! lowered to suite too! the rear flexible brake hoses that go from the rear calipers to the solid lines (where they attach onto the trailing arm bracket) are in need of replacement, however on the new beam the bolts that held braket in place snapped off in the arm on both sides doh! typically only the bolt that holds that bracket on broke, the other 2 (the same bolts that hold the disk protector on) were fine. Rather than wasting several hours and my temperment on drilling them out and re-tapping the holes to refit them, I thought I would use one the good bolt holes, however this would mean longer flexibly hoses to reach the bracket in its new location. are there any recommended brake line suppliers that I can get longer hoses to suit my need or will any brake hose do? cheers in advance. tommer Share this post Link to post Share on other sites
welshpug 1,683 Posted September 1, 2008 just replace the hose with a length of metal brake pipe Share this post Link to post Share on other sites
Pugnut 9 1 Cars Posted September 1, 2008 just replace the hose with a length of metal brake pipe do you mean the hose from the 1.9gti caliper onto the trailing arm? Share this post Link to post Share on other sites
welshpug 1,683 Posted September 1, 2008 do you mean the hose from the 1.9gti caliper onto the trailing arm? yup, do away with the flexi hose, like the 306 and 206 with the same caliper. Share this post Link to post Share on other sites
Tom Fenton 1,585 Posted September 1, 2008 I don't like that idea at all. Solid brake line to moving caliper. A better solution IMO would be to get some -3 fittings and aeroquip line and make yourself up some flexis to go all the way from the caliper to the car. Share this post Link to post Share on other sites
welshpug 1,683 Posted September 1, 2008 (edited) the brake caliper hardly moves at all, a max of 5mm, which isnt a problem IMO and eliminates a section of expensive brake hose and a hydraulic joint. Edited September 1, 2008 by welshpug Share this post Link to post Share on other sites
Miles 331 1 Cars Posted September 1, 2008 I use solid line's now, All 106, 306's etc use that as does the 406 allthou a different caliper and I;ve never had a problem. Share this post Link to post Share on other sites
