John_B 11 Posted July 24, 2008 Anyone know the part number for the diff housing drain plug washer for a BE3 gearbox? It's an Mi and from a BX, but I'd guess the BE3s are all the same? Share this post Link to post Share on other sites
welshpug 1,678 Posted July 24, 2008 servicebox lists it as 2221 32 drain plug and washer. 2221 32 CASING PLUG DIAM 16X150 £1.46 Share this post Link to post Share on other sites
Grim.Badger 15 Posted July 25, 2008 Try and take the plug in to match, most of the time I have tried to get the washer from Pug they give me the wrong one, even when they check the part number. There are two squashable washers afaik and you probably want the bigger one. Personally next time I need one I'm going to buy a box of assorted ones from Halfords Share this post Link to post Share on other sites
welshpug 1,678 Posted July 25, 2008 Grim Badger, gearbox not engine not the case with a BE gearbox, all the same even the box in the T16 has the same plug+washer. the ML box in the larger engined pugs/citroens, and the BE4 in the little more recent cars all use the same plug Share this post Link to post Share on other sites
Grim.Badger 15 Posted July 28, 2008 Still uses a squishable washer and they still gave me the wrong one Grim Badger, gearbox not engine not the case with a BE gearbox, all the same even the box in the T16 has the same plug+washer. the ML box in the larger engined pugs/citroens, and the BE4 in the little more recent cars all use the same plug Share this post Link to post Share on other sites
jeremy 71 Posted July 28, 2008 I have always just reused the existing one with no problems, could you not just do that? Share this post Link to post Share on other sites
Ethos 0 Posted July 28, 2008 The gearbox washer isn't a crush washer so should be ok, but for the sake of 80p odd I bought a new plug + washer. The standard ENGINE oil washers from halfords are the right size and only £1.39 (39p with trade card). Share this post Link to post Share on other sites
Grim.Badger 15 Posted July 28, 2008 The gearbox washer isn't a crush washer so should be ok, but for the sake of 80p odd I bought a new plug + washer. The standard ENGINE oil washers from halfords are the right size and only £1.39 (39p with trade card). I was sure the gearbox drain plug washer was a crush one maybe someone had fitted a crush one on my last car, maybe I'm going mad Share this post Link to post Share on other sites
John_B 11 Posted July 28, 2008 Thanks for the help, the Pug dealers I was passing didn't have any in stock so I re-used the old one. I tried to register with Servicebox but the private tab seems to have gone, can you register using one of the trade ones? Share this post Link to post Share on other sites
