ANDYMISIXTEEN 0 Posted July 22, 2008 I was going to change my Mi16 Thermostat today but relised i didnt get any rubber gaskets with the new one and the old ones are perished. The new thermostat has a little pin where the gasket sits on the old one and the edge is raised where as the old one was flat. Have i got the wrong thermostat or am i just missing the gaskets? It does sit in the hole but the old one is longer. Share this post Link to post Share on other sites
welshpug 1,680 Posted July 22, 2008 its a little valve to let air bubbles through not a pin looks more like an XU10 stat though (not 100% if there's a difference mind) Share this post Link to post Share on other sites
Miles 331 1 Cars Posted July 22, 2008 Just a later and different make of stat, But are you running the crappy water pipe at the back along the cam cover? if not then a std 205 stat is fine or I would block this pipe up as it's not needed on the 205 and only something else to leak and get in the way. Share this post Link to post Share on other sites
KRISKARRERA 2 1 Cars Posted July 22, 2008 Bung it my way lol I use those twin carby stats on the 405! Share this post Link to post Share on other sites
ANDYMISIXTEEN 0 Posted July 22, 2008 Ive got the water piper at the back, is this one alright to use then and should i have gaskets or just use sealant? Share this post Link to post Share on other sites
KRISKARRERA 2 1 Cars Posted July 22, 2008 Does that raised bit get trapped between the cover and the thermostat housing then? Share this post Link to post Share on other sites
dcc 855 Posted July 23, 2008 a friend of mien is not using a 'stat in his vts engine, but he sealed his with some RTV. im sure you could probs use the thermostat and some RTV to seal it? Share this post Link to post Share on other sites
Baz 421 Posted July 23, 2008 Ive got the water piper at the back, is this one alright to use then and should i have gaskets or just use sealant? If you run the silly pipe then no ideally you need the proper stat to run properly! Share this post Link to post Share on other sites
