TRYNKEEPUP 0 Posted July 21, 2008 i have a 205 1.4 i , when driving at any speed has quite a violent judder almost like cutting out for a split second , it dosent do it when foot is flat on floor, cant drive flat out everywhere though !!! sometimes does quite a lot other times just once but it does it every couple of mins, 1 getting a sore head from nutting steering wheel, 2 people think i cant drive ! help, ive changed plugs, leads, tried injector cleaner, any ideas ! cheers Share this post Link to post Share on other sites
kyepan 291 Posted July 22, 2008 (edited) i have a 205 1.4 i , when driving at any speed has quite a violent judder almost like cutting out for a split second , it dosent do it when foot is flat on floor, cant drive flat out everywhere though !!! sometimes does quite a lot other times just once but it does it every couple of mins, 1 getting a sore head from nutting steering wheel, 2 people think i cant drive ! help, ive changed plugs, leads, tried injector cleaner, any ideas ! cheers without steering into carb territory..as a) not my strong point... and upon reading your post again its an I is there oil leaking from the right hand side of the head into the distributor... in extreme cases this may cause the simptoms your describing. especially when you try to accelerate from low speeds in high gears.. at high revs it may be better. secondly, does it get worse when warm? Are the other leads to sensors etc covered in oil and grime.... Edited July 22, 2008 by kyepan Share this post Link to post Share on other sites
bren_1.3 1 Posted July 22, 2008 hmmmmmmm, sounds like theres a block somewhere or the coil pack is breaking down. have u changed the fuel filter? and or coil pack for a known good one? Kyepan: i think this is an injection model...and not carb/dizzy setup. Share this post Link to post Share on other sites
TRYNKEEPUP 0 Posted July 22, 2008 hmmmmmmm, sounds like theres a block somewhere or the coil pack is breaking down. have u changed the fuel filter? and or coil pack for a known good one? Kyepan: i think this is an injection model...and not carb/dizzy setup. it is a single point injection but does have a dizzy, havent looked into that yet, if it was fuel filter wouldnt it do it all the time at any speed ! when we got the car it did this juddering but it was like once every ten minutes ! thought could put up with that its almost impossible to use now cause of this problem, it does it wheather hot or cold, it is a single point injection but does have a dizzy, havent looked into that yet, if it was fuel filter wouldnt it do it all the time at any speed ! when we got the car it did this juddering but it was like once every ten minutes ! thought could put up with that its almost impossible to use now cause of this problem, it does it wheather hot or cold, Share this post Link to post Share on other sites
welshpug 1,682 Posted July 22, 2008 might be the ignition Amplifier, bolted to the side of the distributor on these I'm sure. Share this post Link to post Share on other sites
TRYNKEEPUP 0 Posted July 22, 2008 it is a single point injection but does have a dizzy, havent looked into that yet, if it was fuel filter wouldnt it do it all the time at any speed ! when we got the car it did this juddering but it was like once every ten minutes ! thought could put up with that its almost impossible to use now cause of this problem, it does it wheather hot or cold Share this post Link to post Share on other sites
TRYNKEEPUP 0 Posted July 22, 2008 i think i may have to check ignition side of things, amplifyer, dizzy , rotor arm etc etc Share this post Link to post Share on other sites
