chrisj21 2 Posted July 10, 2008 I think 98041 is the part number but theres a few on there. can anyone tell me which they have used? thanks Share this post Link to post Share on other sites
mrswampy 0 Posted July 10, 2008 cant remember the grade but th titan fuchs stuff is good my local gsf has stopped doing the total quartz products for some reason Share this post Link to post Share on other sites
welshpug 1,678 Posted July 10, 2008 (edited) Fuchs don't do a 75w80, so I wouldnt use it. You might be lucky and find a GSF with Total stuff on the shelf, if not get it from a Pug or Citroen dealer. edit, I found this but probably overkill N98038 GEARBOX OIL-BV 20L £59.20 Edited July 10, 2008 by welshpug Share this post Link to post Share on other sites
chrisj21 2 Posted July 10, 2008 Ok wasn't to sure in the end so i nipped down the local motor factors and got 2 litres of valvoline 75w80 designed for pug/cit gearboxes. hope this will be ok cheers for your help Share this post Link to post Share on other sites
welshpug 1,678 Posted July 10, 2008 yup Valvoline stuff is pretty good, expensive normally! Share this post Link to post Share on other sites
chrisj21 2 Posted July 12, 2008 £5.79 for 2 litres? not bad i thought Share this post Link to post Share on other sites
KRISKARRERA 2 1 Cars Posted July 12, 2008 £5.79 for 2 litres? not bad i thoughtWhere from? Share this post Link to post Share on other sites
chrisj21 2 Posted July 15, 2008 Local motor factors in Hinckley, Leices CAS (central auto supplies) although did buy a clutch/cable so not sure if that made it a bit cheaper. Share this post Link to post Share on other sites
