S13Nick 0 Posted July 9, 2008 hello, right my loom got converted by pr- developments, to fit my 2.0l 8v turbo and have to say he has done a very good job! but there are 2 plugs that i am not sure about????? does anyone have an idea of where they go? its not the lambda sensor! and this one it say ignition amplifier... but this engine doesnt use a coil???????? cheers Share this post Link to post Share on other sites
Anthony 1,003 Posted July 9, 2008 First one is the main ECU/fuel pump relay, and the second one is the ignition amp. Share this post Link to post Share on other sites
S13Nick 0 Posted July 9, 2008 Anthony said: First one is the main ECU/fuel pump relay. where does this plug in then??? lol Share this post Link to post Share on other sites
Anthony 1,003 Posted July 9, 2008 S13Nick said: where does this plug in then??? lol There's a big brown relay that plugs in there - roughly half the size of a cigerette packet. Share this post Link to post Share on other sites
S13Nick 0 Posted July 9, 2008 ahhh ok i dont think i have this, anyone got a picture of one? or the part number for it? Share this post Link to post Share on other sites
welshpug 1,681 Posted July 9, 2008 With that type of plug its more likely to be Black, the relay itself looks the same, but the way it plugs in and locks differs. cant find my pictures of the Later relay, though they are common to pretty much all Peugeot's and Citroen's from mid 95 on. early type plug - early type relay (best pic sorry) Part numbers for early and late relays; 1929 49 RELAY - INJECTION UNTIL DATE 19950108 4549 35 12V 20/30 AMP - INJECTION SINCE DATE 19950108 both are Circa £30-£35. second plug should have an Ignition Amp attached as mentioned, this needs to be from a Motronic system like the 2.0 Mi16 S16 MP3.1 etc, NOT the 1.9 Mi16 or 8 valve systems. Share this post Link to post Share on other sites
S13Nick 0 Posted July 9, 2008 thankyou, do i simply just plug it in and thats all i need to do, as i have a single black cable not attached to the plug does that need to be connected anywhere? Share this post Link to post Share on other sites
welshpug 1,681 Posted July 9, 2008 yep just plug it in, not sure about your Single black wire without seeing the whole loom, if its in the vicinity of the relay its likely to be the main Live feed, were they not labelled? I'm sure a call to Martin @ PRD will clarify any queries you have Share this post Link to post Share on other sites
S13Nick 0 Posted July 9, 2008 ok thankyou for your time Share this post Link to post Share on other sites
