reuben205 0 Posted July 7, 2008 Stupid question but the spring compressors i have seem to be well long and foul the inside of the arch when compressing the spring.It there a method or should i hack some of the length of the threaded rod.I there a method to where to compress the springs etc. Thanks in advance Just need to change the complete struts rather than remove the spring Share this post Link to post Share on other sites
Tom Fenton 1,584 Posted July 7, 2008 You don't need to compress the spring to remove the strut. With the car jacked up, disconnect the drop link, remove the pinch bolt that secures the strut to the hub, and then hammer the hub downwards to release it from the end of the strut. Share this post Link to post Share on other sites
johnnyboy666 195 1 Cars Posted July 7, 2008 to be fair it makes it a bit easier if they are compressed as it takes less heaving to get the strut out of the hub carrier i recon. can you turn the compressors the other way up? Share this post Link to post Share on other sites
Dan Ingram 1 Posted July 7, 2008 The easiest way to do is the way tom suggested. Another handy tip that I nicked of gti-si is to tap a flat headed screw driver in to the clamping bit of the hub that the pinch bolt goes through. That opens it up and the hub just drops off Share this post Link to post Share on other sites
gti-si 0 Posted July 7, 2008 (edited) Just tap in a screwdriver with a large taper, that opens up the clamp nicely and the carrier will just drop out . DO NOT however, do it with the wishbone balljoint clamp, otherwise you could crack it, if not you've a pretty strong chance of ovalling it Edit: Beat to it there Edited July 7, 2008 by gti-si Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted July 7, 2008 I've got a wheel bolt that I filed flat on two sides which fits between the hub & opens the jaws when you crank it thorugh 90' to get the hub off the bottom of the shock. I agree, you don't need any spring compressors to remove it though, fully built up unit should still come out easily using Tom's method. Base models are a different matter though due to the different wishbone antirollbar fitting. Graham. Share this post Link to post Share on other sites
reuben205 0 Posted July 10, 2008 will try that guys thanks,got two s16 front struts to fit just got to remove the hubs off them if anyone wants them when im finished Share this post Link to post Share on other sites
