S13Nick 0 Posted June 16, 2008 hello, i have a set of these sat in the shed, and i tried fitting them on the car but there was no offset of the disk, is this because i tried mounting to 1.6 hubs and , i just thought would it make any difference on 1.9 hubs are ive heard there different in some way apart from the driveshaft cheers Share this post Link to post Share on other sites
tom_m 0 Posted June 16, 2008 xantia activa brakes won't work in the standard system unless you change the seals, they use LHM not brake fluid and brake fluid melts LHM seals. and don't go putting LHM in your brakes because LHM melts brake fluid seals. Share this post Link to post Share on other sites
welshpug 1,681 Posted June 16, 2008 the offset is too low for the 1.9 hubs as well, and as mentioned they work with LHM not DOT fluid. and the handbrake works on the front not the back. Share this post Link to post Share on other sites
S13Nick 0 Posted June 16, 2008 i just thought a cheap upgrade as they came with the car ohwell just have to fork out for some gti-6 or s16 brakes Share this post Link to post Share on other sites
