gerlewislewis 0 Posted May 12, 2008 My NS wing has a few dents and ive thought about getting a new wing fitted and sprayed. Do they bolt off or are they welded on? is it a big job - or would I be better off getting the current wing filled and sprayed? Ger Share this post Link to post Share on other sites
welshpug 1,683 Posted May 12, 2008 (edited) they're easy to fit, getting the old ones off are a mission if you don't want to mash them due to the amount of seamsealer/undeseal thats used as well as the half dozen bolts. depends how bad the dent is, if its creased it'll be difficult to get back to a decent finish without a lot of time and potentially half a tub of filler... a new wing from Peugeot is about £100, add painting and fitting on top. Edited May 12, 2008 by welshpug Share this post Link to post Share on other sites
gerlewislewis 0 Posted May 12, 2008 so are they welded on? or blended into the car frame? as I cant see a join. They are £32.50 on autofive. Ger Share this post Link to post Share on other sites
welshpug 1,683 Posted May 12, 2008 no not welded on, bolted and bonded, not a bad price from autofive, but pattern parts especially 205 wings, never fit that well and tend to rust more readily, there's far cheaper prices to be had if you shop around no doubt, but the quality? Share this post Link to post Share on other sites
toddydal 1 Posted May 12, 2008 if the original wing isnt rusty and not to badly damaged i would repair it rather than put a cheap wing on,like said above it could be a bad fitting wing and not last as long plus you wont be disturbing all the original seam sealer if you repair the one whats on Share this post Link to post Share on other sites
gerlewislewis 0 Posted May 12, 2008 cheers guys, Ill take my car down to the local sprayers and see if he thinks it could be made good as new. Share this post Link to post Share on other sites
gerlewislewis 0 Posted May 13, 2008 the dent master is coming to have a go. £50 I will take some before and after pics and post them on here. Share this post Link to post Share on other sites
Foltan 0 Posted May 18, 2008 if you want a complete new wing the best is to get a new original peugeot one but off ebay or suchlike because then its nearer the price of a new pattern part. pattern parts can occasionally be fine, but wings are notorious for being dodgy on any car because there's so many angles involved. Share this post Link to post Share on other sites
2-Pugs 57 Posted May 23, 2008 Yeah, I agree. I've had experience of pattern wings for 205's in the past. They don't fit properly, and they rust quicker than an old tin can. Either make good what you have or stump up £115 from a dealer. Share this post Link to post Share on other sites
