ifcho 0 Posted May 6, 2008 These days at the office I've been watching quite many crashing videos with a lot of 205s involved and I noticed that most incidents with 205s were caused after crests when the backend lands and then jumps again getting the car out of balance and forcing the car into a spin.. Like this one for example: Comparing the landing of a 205 to a WRC car there is a huge difference... the WRC car even after an enormous jump lands and stays planted to the road in an almost unbelievable way, while the 205's backend starts to bounce around... I guess this behaviour of the 205 is related to the rear shocks mounting angle? And the fact the the shock moves quite a little compared to a mcpherson strut for example and does not have enough movement to dissipate the energy? So I guess the only solution would be converting to rear mcphersons struts? ..except from using some very high end suspension stuff like ohlins/proflex? I wonder, how have the f2000/maxi 306 spec cars solved this problem? AFAIK they are running standard torsion beam suspension at the rear? Share this post Link to post Share on other sites
tom_m 0 Posted May 6, 2008 the ride height and length of suspension travel available to soak up impacts like that just isn't there in a 205. WRC dampers are designed to take it. that and the aero package helps keep the back end down in the air. chris atkinson lost his rear wing in finland one year and landed his subaru on its nose after a jump and the car behaved pretty much just like that video. Share this post Link to post Share on other sites
McDude 33 Posted May 6, 2008 Slightly Off Topic, but the original 205 T16 group B cars were notorious for landing nose first - it properly knackered Ari Vatanen. It was caused by a mid-mounted transverse engine, the polar moment would rotate the car mid-air. It was one of the reasons the Evo version had that enormous wing fitted. Share this post Link to post Share on other sites
brianthemagical 1 Posted May 6, 2008 Would rebound damping help at all? Share this post Link to post Share on other sites
welshpug 1,680 Posted May 6, 2008 yes, 205 Gravel dampers tend to cope better with heavy landings than tarmac ones generally, best I've heard of in a standard beam layout is proflex, but £££££ Share this post Link to post Share on other sites
johno_78 2 Posted May 6, 2008 (edited) Bearing all the previous posts in mind, this evo 6 managed to have the exact same crash i guess it was more a case of too fast for the jump than anything else, in both occurances. Edited May 6, 2008 by johno_78 Share this post Link to post Share on other sites
tom_m 0 Posted May 6, 2008 if you search the jim clark on you tube it seems to be quite a common occurrence! i'm still going with the rear bottoming out, but yeah cos they were going too fast for the jump Share this post Link to post Share on other sites
