SPGTi 2 Posted April 25, 2008 Is there a name / spec for the push fitting of the FPR into the fuel rail ? I want to remote mount an adjustable one and would prefer an adaptor than having to weld on a screw fitting (just in case I want to put the std one back on). Steve Share this post Link to post Share on other sites
DamirGTI 345 Posted April 25, 2008 Which type/brand of the pressure reg. you want to fit ? FSE one or something else ? (for FSE one you don't need to do any welding/adapting , it's a straight fit in the place of the OE one .. and you can swap him with the OE one when ever you wish to ..) Rgs ! Damir Share this post Link to post Share on other sites
SPGTi 2 Posted April 27, 2008 Which type/brand of the pressure reg. you want to fit ? FSE one or something else ? Rgs ! Damir I want a constant rate one, that will either have tails or JIC fittings. Steve Share this post Link to post Share on other sites
SPGTi 2 Posted April 29, 2008 No-one ? It is just going to a constant rate FPR should hopefully make mapping simplier than using a raising rate FPR. Steve Share this post Link to post Share on other sites
