bluespanner 0 Posted April 11, 2008 Does anybody know if the Bosch injector pump off later XUD9T engines in 306s etc will bolt onto my 205? I have been told there is a screw to increase fuelling, and there isnt one on my Lucas pump. Cheers Share this post Link to post Share on other sites
welshpug 1,679 Posted April 11, 2008 you can adjust the fuelling on the lucas pump, the adjustment screw is inside behind the big round cap on the front face of the pump, you need to tun the engine till you can access the allen headed screw. you'll need the bracket for the pump and the injectors if you want to change them though. Share this post Link to post Share on other sites
keith 0 Posted April 12, 2008 it should go on okay, would check on one of the 306 forums but i think quite alot of people change to bosch pumps to run veg oil Share this post Link to post Share on other sites
