neil88 0 Posted March 28, 2008 got trouble with the indicators on a b reg gti, the indicators don't work but the lights work with the hazard switch. tried a new light stork and flasher unit but it's still the same. any ideas Share this post Link to post Share on other sites
christopher 5 1 Cars Posted March 28, 2008 neil88 said: got trouble with the indicators on a b reg gti, the indicators don't work but the lights work with the hazard switch.tried a new light stork and flasher unit but it's still the same. any ideas Replace the hazard switch. You may be able to temporarily fix it by gently pulling the hazard switch from side to side.. Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted March 29, 2008 Are all of you guages & lights working on the dashboard or the heater blower motor? If none of them work, check fuse #2 in your fusebox, the indicators have a seperate fuse to the hazard lights. Graham. Share this post Link to post Share on other sites
neil88 0 Posted March 29, 2008 Thanks for the info, my brother said that all the fuses were OK, will have another look myself Share this post Link to post Share on other sites
neil88 0 Posted March 30, 2008 still got problems all the fuses are ok, there is power going to the switch and the lights light up if you put the live to the light wires but they don't flash Share this post Link to post Share on other sites
woodsy 0 Posted April 2, 2008 do the hazards work.My indicators stopped other week so tried the usual stuff but the hazards still worked.I played around with the hazard switch and that was the cause. Share this post Link to post Share on other sites
