m_pugz_1986
Extra Power On A 8 Valve On Standard Injection System ?
m_pugz_1986
i have a 1.9 8v pre cat engine run on motronic management , i have a performance filter and a full scorpion system on it at the moment .
I was wondering what else i could do ? was thinking on sending the head of to longmans what about the fueling can i increase the fueling by having bigger injectors ? i have the standard orange injectors in there now , also would it make much difference if i had the inlet manifold ported ? as i understand the inlets prefer to be rough on the inside compared to smooth . cams wise i have herd there is no point changing the cam unless go to carbs or tb's but some people have told me to go to a slightly more aggressive cam than the standard one . So what cam is best to use ?
thanks matt :huh:
James_R
for the money you'd spend unless you really want to keep the 8v, 16v is the way to go. not to mention better fuel ecomoney to boot.
richsmells
I'm guessing you have Jetronic rather than motronic if its the standard pre cat injection system. No point using bigger injectors unless you're going for big power. Mi16 engines use the exact same injectors. You would see small gains with a ported manifiold/head, with 3 angle seats, the standard 205 gti head has quite large valves. Some people have fitted a 2.0 8v Xsi XU10 head from a 306 which has bigger inlet valves but the exhaust valves are still normal size.
Some people do fit a cam, but the standard cam is actually fairly lumpy. As you've said anything much larger and you'll need carbs to get the best from it. You'll never get the fueling spot on with standard management. Idle will suffer with anything too lumpy as it makes the AFM flap pulse.
You can fit mapped management from a 1.9 zx volcane or 405 sri (using the zx ecu). The zx has the same engine as a pre cat 205 gti, but runs mapped management. This would improve torque, idle and can be remapped if you fit a cam. It's a lot of effort though as it requires manifold, loom, toothed flywheel from donor cars etc. The cost of all this plus remapping for any modifications would add up to that of fitting a 16v lump.
Short answer. Fit carbs, go 16v or spend money on suspension componets.
Edited by richsmells
its a late Motronic equipped 205 that used to have a cat, till the engine died and Matt fitted a pre-cat engine.
TEKNOPUG
Turbo/Supercharge or fit another engine. Really is no economic sense on spending any money on an 8v
m_pugz_1986
but i do like the low end power and torque a 8 has :)
TEKNOPUG
It has no more low end power or torque than an Mi16/Gti6 - it just feels that way because the 16v's have a rush of power when they come on cam.
Seriously, spending money on an 8v is futile unless you employ forced induction - then they are fantastic :)
Alastairh
Well said that man!
You need to experience 16 valves/boost to appreciate how s*it them na 8 valves are...
Edited by Alastairh
Ormy
Well said that man!
Now now! Nothing wrong with 8 valvers at all!
Yes there is when you want more power than they can offer... :rolleyes:
Otherwise, a good one in fine fettle, they're great!
All the info you need would be uncovered doing a search! :rolleyes:
mad_dome
8v is great my xu9 head was pushing good horsepower not shure what but it used to beat mi16's.
It has now been off the road a number of weeks beacause i am trying out the xu10 head off the 406 as this has bigger valves.
I have also gone for a slightly bigger cam (piper 270) witch is a slight increase from the 268 that comes standard.
i am also useing the so called group a injecters witch turned out to be a load of old bollocks(ebay s*it).
however useing this head involves a lot of work to thee inlet manifold and head its self as you have to ajust the inletports etc. but a very cheapway of doing things. but i have just purchest a gti6 engine so if youcan get one of them then do that :rolleyes: he he.
Peetypug
up until last week i was going to cam and carb my 8v as well as getting some head work done
for the money i have spent on parts for the 8v i could have bought a accident damaged GTI6
so tommorrow i am picking up said GTI6
all my bits are going on ebay, but the best thing is, i will actually save money by doing the conversion (by selling the GTI6 bits)
so i'd say DUMP THE 8V as i was told on a number of occasions "you will not be dissapointed"
why not do a poll on it 8v versus 16v?
Alastairh
Pete, you'll love it :rolleyes:
Matt, i thought you were buying Baz's S16 engine?
Peetypug
Pete, you'll love it :blush:
i'm so excited, i cant wait, i pick it up tomorrow morning :lol::rolleyes:B)
just got to trawl through all the bickering/topics on which is the best way to do the conversion :rolleyes:
m_pugz_1986
meh i still like 8 valves :P i dont know why i just like to stick to them or perhaps it because i cant be arsed doing a engine swap , when i use this car everyday , i can afford it to come off the road for a weekend , but not in the week as i have to get myself into swindon center by 7 am :(
call me a lazy bastard i don't care :P its different when not ur main mode of transport :P
but u never know someone could talk me into changing it , but 16 valves are getting too common conversion for my likening , want to be different me thinks :P
ITB's on a 8valve dont see that much ! hmmmm
Edited by m_pugz_1986
TEKNOPUG
That's fair enough. The power delivery is excellent, just a bit lacking in errr....power.
Seriously though, modding an 8v other than forced induction is a complete false economy. You'd be far better off getting the engine running properly as standard and investing your hard earned on suspension and brakes - then you can always attend to the engine at a later date.
m_pugz_1986
that bit is nearlly done brakes are 266 mm just need some better pads for it now :S as i have bendix crappy things and just need some uprated shocks and some strut braces 309 setup on the front too but a 205 arb , and a 24mm arb on the back im thinking :P
Peetypug
if you get all the parts together you should be able to do an engine swap in a weekend
or am i being a bit adventurous? (and no mine wont be done over a weekend as its in a severe state of malnourishment right now)
if its extra power your after then its cheaper to do the swap, unless somebody on here is selling a ready modded engine
standard 1.9 130 bhp
standard gti6 167bhp
you would have to spend quite a bit on the 8v to get it up to the gti6 power, then you have a car that isnt very good for driving round town, which aint good for an everyday car surely?
m_pugz_1986
well my old minis was like that had a v lumpy cam in :P but i have been thinking gti6 but its not the conversion part its the actual wireing that will have me stumped if someone has a digram i might get persuaded :P
Peetypug
i'm not 100% sure myself
but i'm just gona jump right in but take my time with it
there is no complete list of parts needed so i'm gona make one as i go along, just to help people if i can
knowing me i'll be asking loads of numpty newbie questions that will just get laughed at until somebody takes pity on me and buys everything off me :P
but i do still like the old 8v
check the video in this post
clicky
m_pugz_1986
clicky
see you know u love 8valves on carbs lol sounds live heaven , well i always fancied a mi on twin 45's :P
taffycrook
On comp. cars that have to run 8v's I have had fair results with the std inj system.
1.6 rally cars have shown 140 bhp with not too much spent.
All the talk of 160 bhp 1.9's is possible but not on a budget.
Engine swops make sense, as does turbo charging however, in real world terms my 205 8v track day car is as quick as a mi16 around the circuit with around a 20 bhp diss-advantage.
The new engine build is going to hopefully put me on par with a std mi16, but this will cost around another 500 quid.
On top of carbs, mapped ign and the rebuild.
Alastairh
Yup. Thats why after doing most engine conversions on 205s now id go back to a GTI6 if i had to. For the money to power to fuel economy for a daily drive id like to see someone better it...
Pffft, that was old news, tbh i didnt really expect that to come to fruition, i think you know why... :blush:
Matt Holley
see you know u love 8valves on carbs lol sounds live heaven , well i always fancied a mi on twin 45's :wacko:
You can come out in my gti6 on carbs if you need some convincing on 16v power :D
