weejimmy 1 Posted January 25, 2008 hi i have an 205 diesel and a stdt both cars run lucas pumps and i was wondering if i can change them to the bosh pump off a 405/306? anyone know??? Share this post Link to post Share on other sites
Tom Fenton 1,564 Posted January 25, 2008 Yes you can change them to Bosch pumps, you will need the pump, pipes and injectors. Share this post Link to post Share on other sites
weejimmy 1 Posted January 25, 2008 sweet that was easy thanks man Share this post Link to post Share on other sites
welshpug 1,682 Posted January 25, 2008 not quite that easy, they will need re-calibrating as they are intended for a larger capacity engine and higher boost pressures (and lower intake temps due to an intercooler) Share this post Link to post Share on other sites
weejimmy 1 Posted January 25, 2008 well ave got an intercooler of my rx7 that i coud use as its quite small and should be easy to find space for. or a itercooler from a 306 td. i did think ad have to re-calibrate it to but thats ok. but i might just put the whole engine in ... mmmm decisions decisions Share this post Link to post Share on other sites
Big_Jimbob 0 Posted January 28, 2008 im in the middle of this conversion, mainly so i can run on svo (straight veg oil) the car is going in to be calibrated and have a cam belt change at the same time... ill let u know how it goes... thanks Jim Share this post Link to post Share on other sites
foreigner 0 Posted January 28, 2008 im in the middle of this conversion, mainly so i can run on svo (straight veg oil) the car is going in to be calibrated and have a cam belt change at the same time... ill let u know how it goes... thanks Jim it is easy to swap whole engine compare to play with new pump, 1.9 td is the same size engine as 1.7. I have done twice and it works. Share this post Link to post Share on other sites
weejimmy 1 Posted January 28, 2008 how do you mean the 1.9td is the samr SIZE as a 1.7 do you mean physicly ie it fits in car? Share this post Link to post Share on other sites
