tonycj
What Mpg Should I Get From My Cj?
tonycj
Seems to me that i am constantly filling up my CJ with fuel (1360cc engine), i can get about 250 miles out of my tank, which i think isnt a lot.
Can anyone give me any idea if this is fine or not?
Also when i am running around in the car it seems to cut out every now and again, only for a fraction of a second but its realy annoying, i think it may be fueling but im not sure, ive changed the plugs, leads, dizzy cap and rotor arm so i think the electrical side of thinks should be OK.
Any ideas welcomed,
Tony.
kate205gti
does it smell of petrol?? mine ran way too rich! think it still does :unsure: (davew got it now! :lol:)
Sandy
The 1.4s are usually good for around 40mpg. Less than that and something's likely wrong.
GazRallye
I got 37 mpg with combined driving over 270 miles and it does over 300 miles on a tank (not sure if CJ tank is same as XS)
Check the fuel lines under the car and inside the 'bay around the pump and filter
RossD
Yep, my old 1.4 gave me about 40 - 42mpg. The CJ may give slightly less as its a bit heavier.
Jrod
I get about 30. Don't think anythings wrong with the car, just my heavy foot.
Rippthrough
I got 15mpg over christmas, but a change of fuel side parts and I was back up to ~35mpg - which is about normal for it.
After sorting the new head out last week I actually seem to be doing better on fuel even with another 20bhp :)
DaveW
  kate205gti said:
does it smell of petrol?? mine ran way too rich! think it still does :) (davew got it now! :P)
Its been tweaked now, it just smells of fuely oil :blink:
tonycj
Can anyone recommend anything i should do then? over the last few days the shuddering whilst driving has got worse!!
Fuel pump on its way out?
Single point injector gummed up?
i dont know of anything else i could look at!
Many Thanks and i look forward to your replies again.
Tony.
DaveW
Oh its a spi engine? could need a new fuel filter then.
Rippthrough
Lambda sensor and the throttle position sensor are both killers for the fuel consumption on the SPI if knackered/incorrectly adjusted.
Last Legend
I would check out the fuel pump (access to it under the rear seat) might also be worth having it rolling roaded and see what its set up like.
Do you know where it was MOT'd last?A quick phone call will see what the emmissions were like at the time.
