mad_dome 1 Posted January 11, 2008 just about to buy a 264 fast road newman cam is this wise idea? Share this post Link to post Share on other sites
j_turnell 137 3 Cars Posted January 11, 2008 Might help if you elaborate a little. What you using the car for? Any other engine mods? Not sure what the standard cam is off the top of my head but 264 sounds pretty low as the piper 270 is basically the standard equivalent, sure someone else can shed more light on that one. Share this post Link to post Share on other sites
Tom Fenton 1,584 Posted January 11, 2008 From a close friend of mines personal experience I would never use a Newman camshaft myself. Share this post Link to post Share on other sites
mad_dome 1 Posted January 11, 2008 what went wrong for your mate? my car is standard apart from a full exhurst system. i could eaither have a 264 as the standard cam for my engine is 270 i think or i could go with a 280 cam. this is for my 1.9 8v gti. what would be best 264 or 280???? Share this post Link to post Share on other sites
j_turnell 137 3 Cars Posted January 12, 2008 I would do a search and look into other options such as catcams. Are you going to be using standard injection as this has its limitations?? If all your doing is throwing a cam in then you wont see that big improvments really, its a combination of things that you see differences. Share this post Link to post Share on other sites
Fast Road Jay 0 Posted January 12, 2008 264 is a downgrade! 280 should show a small improvemeant tho Share this post Link to post Share on other sites
mad_dome 1 Posted January 12, 2008 yes i could get 280. but am unsure now! i made a mistake on my first post! i was going to buy a 268 cam. but he did say u could go for the 280 here are the stats of the cam i am looking at buying please shed some light on this. A Newman camshaft 268 deg suitable for 8V 1.6 1.9 Peugeot 205 GTI and 309 GTI The camshaft has been cut to high specification on a new quality blank, note this is not a re-grind camshaft. The camshaft when fitted correctly will give good power/torque gains especialy in the mid, with little low end loss. This is a good fast road for a fairly standard engine, free reving cam for the 8V engine. 11.93 inlet lift,11.88 ex lift timing 24/64 64/24 280 deg and 300 deg are also available. Please look at http://www.newman-cams.com/pdf/peugeot.pdf Share this post Link to post Share on other sites
Richie-Van-GTi 74 2 Cars Posted January 12, 2008 what people are saying is the cam you are looking at is milder than the standard cam, the standard cam is closer to the 280 cam in terms of performance. I switched from a 280 'performance' cam to a standard cam with no other changes and felt no difference in the engine. If your parting with hard earned cash then get something that will give you a noticeable gain, otherwise you will feel cheated. Share this post Link to post Share on other sites
ifcho 0 Posted January 14, 2008 Tom Fenton said: From a close friend of mines personal experience I would never use a Newman camshaft myself. why is that? I have asked before here for newman cams and the responses were very good. Actually my "tarmac rally sprint" cam just arrived. Share this post Link to post Share on other sites
mad_dome 1 Posted January 14, 2008 Ok everyone just bought myself a ported and polished head skimmed to 7mm with piper 270 fast road cam. Group A injecters with fse boost valve. ported and polished throtel body. kn induction kit Can anybody shed some light as to what sort of effects this will have on my performace? Share this post Link to post Share on other sites
hodgy 0 Posted January 17, 2008 bin the 270 cam and put a proper one in.i had a 270 cam in an engine and it was no different to standard where as i noticed a difference with a 285cam Share this post Link to post Share on other sites
