NeilGTi85
Flashing Dash Lights?
NeilGTi85
Hello all,
This maybe a stupid Question but why does my oil temp guage flash when i turn the ignition (not turning the car on, but when im using my CD player etc....).....maybe because its cold??
Neil
(1.6 GTi 1985 model)
danpug
I could be wrong but isn't it normal for all the gauges to do this when you turn the ignition on without starting up?
NeilGTi85
No its not normall, it must be a warning light......
danpug
Just been out in mine and tried the same thing, oil temp and oil pressure warning lights come on then turn off when engine starts. No need to worry!
NeilGTi85
but mine keeps flashing!!!
something is wrong, it does not always do this??? but recently has been doing it...
There isn't an oil temp light at all.
If the oil temp gauge is flickering then the wire has probably come off of the sensor on the sump, if it touches the gearbox or subframe etc it will read maximum.
