Spiky 37 Posted December 15, 2007 i've never fitted one of these so i assumed i removed the OE water/oil cooler (like on cossie's) and put new thermostat controlled sandwich plate and job done?? :? :? but i cant, if you look at the pic below one is the OE bolt that holds the old cooler on, which has male fittings each end yet the new one has male one end female the other, it's as if i just attach the new sandwich plate to te OE one and just not use the water pipes :? :? or do i have the wrong fitting???? or just being stupid :? :? Share this post Link to post Share on other sites
welshpug 1,629 Posted December 15, 2007 tried the new sandwich plate with the old bolt? Share this post Link to post Share on other sites
Spiky 37 Posted December 15, 2007 but the plates are different size diff thickness Share this post Link to post Share on other sites
Discostu 6 Posted December 15, 2007 I had the same problem with mine, mikey took it into work and reworked it on the lathe. try pm'ing him Share this post Link to post Share on other sites
Spiky 37 Posted December 15, 2007 fook that, i paid good money for this, i want the RIGHT part, best speak to my seller then Share this post Link to post Share on other sites
309Dimma 0 Posted December 15, 2007 I had the same problem, until I found out that the upper "bolt" in your pic isn't one but two. You can take them apart and use one of them. If I remember right... Share this post Link to post Share on other sites
Spiky 37 Posted December 15, 2007 really? back to garage then, be 5 mins.....lol Share this post Link to post Share on other sites
Spiky 37 Posted December 15, 2007 well mine seems one peice looks one peice inside Share this post Link to post Share on other sites
Spiky 37 Posted December 15, 2007 lol i actually was 5 mins...lol Share this post Link to post Share on other sites
steve@cornwall 100 Posted December 15, 2007 Isn't the water cooled - (or heated?) one usaully used with a remote filter bolted to the bellhousing? I'd have thought 1 or the other, unless I've got the wrong end of the stick, you're looking at running a cooler AND a warmer???? Share this post Link to post Share on other sites
309Dimma 0 Posted December 15, 2007 Now I know how I did it! Just unscrew the thread on the right on the upper bolt. Then use it as an extension to the lower bolt. If you don't understand what I mean. Look what differs the two bolts. The thread on the right. Share this post Link to post Share on other sites
309Dimma 0 Posted December 15, 2007 It looked like this when I was done: Share this post Link to post Share on other sites
Spiky 37 Posted December 15, 2007 i understand but 2 issues 1, it really dont look like it will seperate( thats not to say it wont) 2, i got no way of splitting them..lol Share this post Link to post Share on other sites
309Dimma 0 Posted December 15, 2007 It's thread lock on them... I used a pipe-wrench (I don't really know the english word) with a cloth in it, not to ruin the thread. Share this post Link to post Share on other sites
Spiky 37 Posted December 15, 2007 ok back to garage...lol i have a pipe wrench Share this post Link to post Share on other sites
Spiky 37 Posted December 15, 2007 nope that didn't work..lol i've be told i need the bit you mention, so will get one, but i guess this one dont split.. cheers for the info though Share this post Link to post Share on other sites
309Dimma 0 Posted December 15, 2007 Sorry it didn't work. Now youv'e tried anyway. Share this post Link to post Share on other sites
Spiky 37 Posted December 15, 2007 and killed it...lol it's not needed anyhow Share this post Link to post Share on other sites
Miles 331 1 Cars Posted December 15, 2007 Easy, As all the Iron blocks with the heat exchanger fitted use the fitting as in your picture and is one complete item, On the alloy blocks they still had the thread insert in the block, You can buy these from Pug for a couple of quid, If you need the part number drop me a PM Share this post Link to post Share on other sites
Spiky 37 Posted December 15, 2007 yeah, can i have the part number, just in case my supplier doint know this info cheers miles Share this post Link to post Share on other sites
309Dimma 0 Posted December 15, 2007 It's 1103 54 you need. It mesaures 20X1,50-27 and is originally from the XU9JA with an aircooled oilcooler. Right Miles? Share this post Link to post Share on other sites
Miles 331 1 Cars Posted December 16, 2007 Thats the one, The info is on my other PC Share this post Link to post Share on other sites
