Guest puggti
Engine Mounts
Guest puggti
ok, now my engine mountings seem to be shagged, i have changed the top one which i belive is the easiest
What other ones are there and are they hard to change?!?!
I will have the gearbox out soon so is there on to replace here too?!?
C_W
The one on the gearbox (under the batter) is easy to change. When you take the battery off there will be two 13mm nuts and a larger 18mm nut holding the pin from the gaerbox up in the mount.
Guest himbigchief
One more on the bottom rear of the engine. Bolts the engine to the subframe iirc.
James
sleeper205
just to let peeps know, 205 TU and XU bottom mounts seem to be the same.
i can't see anything physically different about them.
Guest puggti
Ok u see this bottom one is it a bugger to change?!?
Guest doughboy
Not if you take the whole casing to a garage with a press :ph34r:
Guest puggti
can i buy the bottom one?? if so where shall i get these mounts from
Am i right in thinkin that the 405 uses the same mounts?!?
If so where can i get them from>??
Thanks for all ur help
Guest timH
the bottom one is a bitch to change, unless you take it to a garage with a press, like said above.
Did mine with a BFH, and still didn't get it entirely in the right place.
The 2 top ones are dead easy.
good luck.
Guest puggti
can i not buy the bottom one complete?!?
If so where shall i get my mountings from??
GSF?
205man
euro car parts charge £4.25+vat for just the lower mount itself or £44.50+vat complete, would be cheaper to just but the mount and pay about a tenner for someone to press it in.
peugeot charge about £90 for the complete thing
alan
Guest puggti
But is the bottom one EASY to change apart from the pressing?
Guest puggti
ok i went to GSF and bought some engine mounts, i asked for every1 they have for the 205 gti, i got given a circle thing with rubber in side and another circle thing with something sticking out with thread in it!! They confused me!!
Any1 got any photos of what the mounts should look like, ie the one under the battery tray and the one on the subframe so i can see if i have the right ones!!
Also i need to get the one near the cam belt end, i can see what this looks like so i dont need fotos of this!!
Pug
Guest doughboy
mounts
top left with gold bit on top is gearbox mount.
below that is the lower mount.
the 3 bits on the right make up the upper mount.
Guest puggti
Thanks mate, i have the top right one and the bottom left one (the bottom letf one i have looks a little bit diff with the same metal casing and the rubber inside, it doesnt have the silver bit on it but has a hole so it will do!!
The one on the top right is that easy to fit, is that the one under the battery tray?
Not bad for a tenner
Guest doughboy
nope, that's the top left one.
they will look slightly different cos that pic is of the group n ones.
Guest puggti
So the top right one goes where then?
Guest doughboy
look 4 posts up m8. :ph34r:
Guest puggti
ok yeah thanks
Any1 else want to help me??
