dean 0 Posted September 30, 2007 does any one no wat clutch to use when putting a gti6 and gearbox into a 205 cheers dean Share this post Link to post Share on other sites
Guest NickMiami Posted September 30, 2007 405 MI16 clutch on the 205 'box Share this post Link to post Share on other sites
welshpug 1,683 Posted September 30, 2007 nearly right! 1.9 Mi16 clutch, 2.0 mi16 pressure plate is identical to the gti6 clutch, but still 215mm diameter and the same spline patterns. Share this post Link to post Share on other sites
dean 0 Posted September 30, 2007 and will that fit with a gti6 box Share this post Link to post Share on other sites
welshpug 1,683 Posted September 30, 2007 nope, for the GTi6 box you need a 2.0 Mi16/S16/GTi6/XSi etc clutch to use the gti6 box (nearly all the XU10 and XUD9T clutches are the same "Pull type") Share this post Link to post Share on other sites
dean 0 Posted September 30, 2007 ok so then what clutch cabel will i need to use so it will fit the box and the bulk head on the car Share this post Link to post Share on other sites
welshpug 1,683 Posted September 30, 2007 for which box? and is the car BE1 or 3? Share this post Link to post Share on other sites
dean 0 Posted September 30, 2007 for the gti 6 box. the car is an opposite 5th reverse, so obviously i would need to get a lift up reverse cable. Share this post Link to post Share on other sites
Hilgie 16 2 Cars Posted October 1, 2007 You can retain your current BE3 cable, but you will need to add a lift up reverse from a BE1 car. Share this post Link to post Share on other sites
dean 0 Posted October 1, 2007 what so use a be3 cabel and a standard gti6 clutch Share this post Link to post Share on other sites
