kyepan
Fuel Tank
kyepan
Hi there,
Need to change the fuel tank as my exaust is wearing a hole in it.. a firey death following a small prang is reserved for 1960's f1 drivers.. not me.
anyhow, hows it done? is it in the haynes? Are there any seals and pipes i should change whilst i'm on the job. does anyone have part numbers for the hard pipes that run under the car, because they are rusty
cheers
J
It easy enough to remove, two 13mm M8 nuts at the back & the filler pipe jubilee clip in the wheel arch.
Best to run an M8 nuts along the threads for the mounting stud first to clean the rust etc off them & get some pentrating oil on the nuts to ease things.
I think the fuel pipes are still available but its easier to buy a roll of 8mm copper fuel pipe & use that imo.
They should be listed on Pug parts.
Graham.
kyepan
Graham.
good shout on the parts catalogue, will look into it. cheers
J
