BackStreetRacecars
Rear Bump Stops
BackStreetRacecars
When lowering the rear end of my car my mate that was helping me broke both the rear bump stops off by mistake, are they still available from peugeot or am i better off getting competition efforts? also how much of a pain are they to fit??
Grim.Badger
Yes Pug still have them (or did not long ago) and they are about £6.50 including the cup that they fit into.
They can be a pain to fit if the bolt that holds them on is rusted up but otherwise are simple.
When I tried to change one of mine the panel that the old one was bolted to just pulled off when I tried to undo the bolt ;)
hodgy
i just run without bumpstops and mine has been fine
Simes
Check the rear valence and you'll see where the rear wheel strikes it under load.
brianthemagical
grease is helpful putting the rubber bits in to the cup.
hodgy
mines stripped out so there wont be any load so im fine lol
Ben_M
I changed mine about 6 months ago it cost me £11.50 from Peugeot . one of the bolts was hard work to remove but mole grips and a little bit of heat and it was out in no time..
As for running it with out the bump stops, my didn't have them on for 5 years. this wasn't a problem as the car was lowered but one spline and running Koni Adjustable rear shocks. It only started to rub when I went back to standard shocks and left the beam lowered. Ended up returning the car back to standard.
hope this helps in some way! Ben
