engine killer
My Double Quick Shift
engine killer
I have my gear change mechanism modified and would like to share it with you all.
http://rides.webshots.com/photo/2192611240084130750TEYxAI
this shows the different between TAS (top & bottom) and original. the bottom part of the lever is about 10mm longer (measured from the pivot point) and this gives a shorter throw. somehow if you look at the top TAS carefully you will see there is a small hole about 35mm above the pivot point, it will CRACK and this is why I have my second one sleeve into a stainless tube and made it longer (which offset the short throw purpose).
http://rides.webshots.com/photo/2701635130084130750OCSsgp
http://rides.webshots.com/photo/2307235060084130750OzHrAK
extending the L-plate is always the best and cheapest solution for quickshift. you can see my L-plate has three holes to give adjustability.
http://rides.webshots.com/photo/2200337260084130750OCWtEy
http://rides.webshots.com/photo/2129228020084130750Vtiujp
http://rides.webshots.com/photo/2549215260084130750gvzKso
since the lever is extended, the knob is now much closer to the steering wheel and allows the time of my left hand leaving the steering wheel shorter during gearchange and i do not have to lean forward at all (with my short arm).
:D
Super Josh
That looks good :D What are the switches for on your dash? Are the two on the right for front and rear fog lights? Is that standard for a HK model? I assume that the far left is for the AC? The UK models actually have the letters 'AC' on the switch.
I like the 'one touch' window switches too :)
Josh
engine killer
  Super Josh said:
That looks good :) What are the switches for on your dash? Are the two on the right for front and rear fog lights? Is that standard for a HK model? I assume that the far left is for the AC? The UK models actually have the letters 'AC' on the switch.
Josh
yes one for A/C which is standard for Hong Kong market and the green one is front fog light (used to be driving light, but i bought the switch to make it switchable even when low beam is on).
the one touch, the 405 switches fit perfectly and my friend used the switchbox (little ecu) from a 306. and I have one touch on both side. :D
hodgy
that rev counter is cool as foooook. i want one. i have the same kind of set up with my gears too except my stick bangs off the exhaust in 1,2 but rest are fine. took some getting used to kept going to 5th instead of 3rd
tom_m
yeah i've got a similar set up, love the quick quick shift :) third doesn't like it much tho :(
engine killer
the quick quick shift can easily be achieved by extending the L-plate about 1 1/2" to 2". but 2" extention will just make your shift very unclear/unprecise, i have tried but i just did not like it at all.
tom_m
no i mean i love it, i've got an extended L and an extended lever, with a set of metal ball jointed alloy rods, all adjusted to give a proper short precise throw.
