Dandu 0 Posted August 7, 2007 Hi, I'd like to know if there is a common orientation for setting up the air/fuel-ratio. In my view I'm in need to achieve the following: 1. Idle: Lambda 1 2. Partial Throttle: Lamdba 0,96 (constantly at 3000rpm, 4000rpm f.e.) 3. Wide Open Throttle: Lambda 0,86. Much thanks in advance. Cheers Dandu Share this post Link to post Share on other sites
petert 617 Posted August 7, 2007 Dandu said: Hi, I'd like to know if there is a common orientation for setting up the air/fuel-ratio. In my view I'm in need to achieve the following: 1. Idle: Lambda 1 2. Partial Throttle: Lamdba 0,96 (constantly at 3000rpm, 4000rpm f.e.) 3. Wide Open Throttle: Lambda 0,86. Much thanks in advance. Cheers Dandu I can't recall exactly how the lambda values match up with AFR, but it should be more like this: 1. Idle - 12.5 - 13:1 2. Part throttle, cruising - 14.7:1 (lamda 1) 3. Moderate loads around 13.5:1 4. Full Load, WOT - 12.7 - 13.0 (lamda 0.9?) Share this post Link to post Share on other sites
Dandu 0 Posted August 8, 2007 Much thanks Peter. I'm going to find a compromise. Bye Dandu Share this post Link to post Share on other sites
