Retro Pug 0 1 Cars Posted July 31, 2007 Hi All, I've tried searching but cant seem to find what I'm looking for. I'm thinking of buying a compressor suitable for spraying body pannels. I've got around £300 to spend is the realistic or am I just spraying in the wind? Also which other tools would I need to achieve an aceptable finish? How much extra should I budget for these? Many thanks John. Share this post Link to post Share on other sites
welshpug 1,682 Posted July 31, 2007 its not so much the compressor itself that is important when spraying but the size of the resevoir, so If youve got the space for some extra tanks any decent compressor will do the trick. Share this post Link to post Share on other sites
SPGTi 2 Posted July 31, 2007 Have a look HERE . This explains what you need to consider for spraying. Then think if you will want to use a DA sander as well (use lots of air!), find out the air consumption of this and see if this changes your requirements. I have a cheapo Aldi compressor (£50) but my main use is impact wrench, blowing up tyres, drill, ratchet and most of these operations are short bursts so it has plenty of time to recover. It does struggle with a cutter I have but I did paint the garden fence panels using a gravity fed gun without too many problems (prolonged spraying would sometimes drain the reservoir though). Steve Share this post Link to post Share on other sites
Retro Pug 0 1 Cars Posted July 31, 2007 Thanks for the replys, I have much more of an idea now. Cheers John. Share this post Link to post Share on other sites
Richie-Van-GTi 74 2 Cars Posted July 31, 2007 if your on a budget its often better to buy a second hand one with a much bigger resevoir. Share this post Link to post Share on other sites
sutol 0 Posted July 31, 2007 There is an article in PPC this month explaining compressors and how to choose. I'm still not sure. Share this post Link to post Share on other sites
Retro Pug 0 1 Cars Posted August 1, 2007 sutol said: There is an article in PPC this month explaining compressors and how to choose. I'm still not sure. Nice one, I'll pop out and buy one later on. Thanks. Share this post Link to post Share on other sites
mattmk1 0 Posted August 1, 2007 It all depends on the cfm of the compressor, and what you are painting. A DA sander will take around 15 CFM, a spray gun will take 14-16 CFM althought they all vary, and a spray gun with an air fed mask will take 24 ish CFM. Size of the reservoir doesnt really matter that much when spraying, we use a hydrovane that doesnt have a receiver tank at all lol. Share this post Link to post Share on other sites
