phil05
Alloys
phil05
Just wondering if a set of 15inch compomotive alloys from a "F" reg mark 2 golf gti would fit on a 205 GTI, if so would they need spaces
Cheers :)
Nope - PCD is different (4 x 100 and 4 x 108 IIRC) so they won't fit I'm afraid.
Ford fitment wheels will fit with spacers though, and Compo's seem to be fairly commonly available second hand in Ford fitment
sonofsam
No they wont fit, different PCD, you can fit Ford wheels to peugeot ( wich will need spacers )
and that's about it without major hub mods
see for yourself :)http://www.carlsalter.com/wheel_fitments.html
My compomotive MO's will be up for sale soon wich have the right PCD and offset.
phil05
Cheers you two was just an idea, on that website it says about the the "bore" what does it mean :) just for the future
sonofsam
Bore is a great big f**kin pig :):o
Only joking, it's an engineering term for a hole and it's size
so to relate that to wheels it's the hole(bore) in the back of the wheel that locates onto the hub/stub axle.
Edited by sonofsam
thats bOAr not bore sam :)
peugeot use 65.1mm, Ford uses 63.4mm
you can get adapters to go from pug to ford, and there are even bolt on adapters to go from 108 to 100mm so you can use renault wheels etc.
phil05
haha cheers mate
Lots of aftermarket wheels use a large std sized centre bore then use spigot rings to fit inside this to shim down to the required size too.
