rossi 0 Posted July 10, 2007 Right, it's bugging me now. Pretty sure it's a Be1 box on 1.9 ph1.5 (Lift up and reverse top left). Clutch is all the way to the floor, and no matter what I do 1st -5th to reverse, it always grinds when the engine has warmed up. However, when the engine isn't quite warm, it doesn't grind at all? Whats the deal here? I've thinkin clutch cable adjustment. Anyone confirm this? Share this post Link to post Share on other sites
jackherer 543 Posted July 10, 2007 rossi said: I've thinkin clutch cable adjustment. Anyone confirm this? Yes, sounds likely. Also check the arm the cable connects to on the gearbox isn't bent as they fatigue with age on be1 boxes. Share this post Link to post Share on other sites
Richie-Van-GTi 74 2 Cars Posted July 11, 2007 ditch the oil and put fresh in if its temperature related, sounds like low level or incorrect oil. You need 75/80. I reccomend total BV. Share this post Link to post Share on other sites
rossi 0 Posted July 11, 2007 How many litres does it take to fill up a box with fresh oil? Cheers for replies. Share this post Link to post Share on other sites
Richie-Van-GTi 74 2 Cars Posted July 11, 2007 2 litres Share this post Link to post Share on other sites
A2TheA 0 Posted July 29, 2007 befoe selecting reverse try seecting 2nd first. i was told by a friend and it seems to work for me. its become some what of a habit now. Share this post Link to post Share on other sites
steve@cornwall 100 Posted July 29, 2007 First signs of loose gearbox - engine bolts?. Share this post Link to post Share on other sites
