Peetypug
Phase 2 Oil Cooler
Peetypug
just bought a phase 2 oil cooler for my 1990 sorrento :unsure:
only problem is it wont fit due to the bracket that houes the power steering pump :rolleyes:
only thing i could think was dump the power steering and get a quick rack (saves weight and the wife wont want to drive it then) :(:wub::D
any other sollutions/ideas would be gratefully recieved
Super Josh
What do you mean by a 'phase 2 oil cooler'? The PAS and AC models are fitted with the oil/water heat exchanger that bolts to the side of the gearbox. This moves the oil filter to the side of the gearbox to make changing it possible with the PAS or AC gubbins in the way. Look here
Josh
Peetypug
sorry i should have been more specific.
i bought a later style oil cooler with the rad that bolts where one of the fans goes
Richie-Van-GTi
I thought that was the earlier type? Either way, ditch the PAS pump and ram, IMHO gives a much better steering feel.
Super Josh
Yep, that's the earlier type.What are you trying to acheive here? your PAS equipped car should already have the oil/water heat exchanger fitted, that I mentioned in my post above.
Josh
Peetypug
so i've taken a step backwards have i?
i thought the oil rad was from a phase 2 :)
which is better? oil rad or water cooler?
Peetypug
thanks josh, its the 1st gti i've had and i'm still learning something new everyday (i've had it 4 years)
i thought that the oil cooler (radiator) would cool the oil better than the water/oil cooler
and i wanted a nice silver oil cooler behind my bumper :unsure:
Edited by sorrentopete
Richie-Van-GTi
the later heat exchanger is better as the early ones dont really do much of anything. the newer ones warm the oil up quicker then maintain its temperature better.
Peetypug
thanks richie
will probably still get shot of the PAS tho :unsure:
i notice your putting r1 bodies on your car :unsure:
how are you sorting the manifold?
i've got sum r1 carbs and i'm waiting for a manifold from bogg bros, just takin thier time making it(bin 10 weeks when they quoted 5) :(
Richie-Van-GTi
Ive used a cut down MI manifold but my engine is 16v so spacing is totsallly different. before this I had a 2.0 8v on gsxr carbs, sold the carbs and mani for £190 with pump and reg. That was a bogg bros mani for R1 carbs as well.
