driversdomainuk 8 Posted June 13, 2007 Hi I am possibly looking for a performance cam for my 8v but do not want expenditue and time of raising CR and also risk busting engine. I am running twin 45's Do Kent do any good ones, bearing in mind I need lower/mid end power and not top end as I am using it for hillclimbs. thanks Share this post Link to post Share on other sites
brianthemagical 1 Posted June 13, 2007 catcams and qep, so i've heard, no direct experiance though. Share this post Link to post Share on other sites
petert 615 Posted June 14, 2007 Don't change the cam then. You'll only go backwards if you change the cam and don't increase to at least 10:1. Share this post Link to post Share on other sites
niklas 1 Posted June 14, 2007 Find a milder cam with less overlap than OE Share this post Link to post Share on other sites
Anulfo 22 Posted June 22, 2007 Find a milder cam with less overlap than OE The piper 270 is a good cam,decent spread of power and still quite usable for everyday driving. I had an engine done by pug performance with a piper 270 and on twin 45's and it made 156bhp at wheels,admittedly it did have a big valve head though.I was always told that kent cams are probably more suited to fords? Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted July 2, 2007 The piper 270 is a good cam,decent spread of power and still quite usable for everyday driving. I had an engine done by pug performance with a piper 270 and on twin 45's and it made 156bhp at wheels,admittedly it did have a big valve head though.I was always told that kent cams are probably more suited to fords?The head needs to be skimmed when you fit a Piper 270' cam kit. They aren't much different to the standard cam either so find the best tolerance standard cam you can & use that but even this cam would benefit from giving the head a skim. Graham. Share this post Link to post Share on other sites
