webby997 0 Posted June 13, 2007 I'm having problems with my 1.6gti (j reg).The problem is it doesnt start,it might start now and then but will not start all the time.It will though easily start when bump started.I've wiggled connections etc and the battery is only a few weeks old.Any help/advice would be much apprecaited.Thanks Share this post Link to post Share on other sites
Mikey G 3 Posted June 13, 2007 Could be a bad earth, check the aerth connections on the gearbox and body near the battery. While your cranking the engine a bad earth could be taking all the power away from the ignition circuit which is why it will start on a bump. Share this post Link to post Share on other sites
steve@cornwall 100 Posted June 13, 2007 webby997 said: I'm having problems with my 1.6gti (j reg).The problem is it doesnt start,it might start now and then but will not start all the time.It will though easily start when bump started.I've wiggled connections etc and the battery is only a few weeks old.Any help/advice would be much apprecaited.Thanks have you tried to bump start? this may point to ignition amp if it will fire from a bump start Just read this reply (By205007) in another thread http://forum.205gtidrivers.com/index.php?s...76430&st=10 Hope it helps Share this post Link to post Share on other sites
ashlee205gti 1 Posted June 13, 2007 Spade connector on starter motor? Usually down to the brown multiplug. Share this post Link to post Share on other sites
brianthemagical 1 Posted June 13, 2007 does it turn over? Share this post Link to post Share on other sites
webby997 0 Posted June 16, 2007 Thank you for all the replys.It seems to have been solved after taking off and putting back the dizzy cap.-cheers Share this post Link to post Share on other sites
