Spiky
Gti-6 Rev Counter Issue
Spiky
on the following thread
http://forum.205gtidrivers.com/index.php?s...mp;hl=gti-6+rev
it's mentioned to join two of the ve+ wires together, surely this isn't a good idea???
does the ve+ not do any pulsing to ignite the spark? or is it just a constant live?
sorry i just dont understand it, but just though linking both ve+'s together was a bad i deal
anyone explain it for me??
cheers
pugrallye
no you take the negative, which is actually the ecu 'trigger' wire.. ecu creates an earth (its down to collapsing magnetic fields) and you take a feed off coils 1 and 2 (& 3 and 4 on a GTi 6 as it doesnt have wasted spark) and create circuit as posted elsewhere using 2 x diodes (4x for a gti 6) 1 x zener diode and a resistor, zener diode is blocking the 6V it 'sees' until coil is triggered (basically when rev counter sees a 0V it flicks) tried to explain it as basically as I can, sure others can elaborate more in laymans terms, but you have any doubts you should really seek guidance from an auto electrician as getting it wrong and shoving 300V up an ECU could let the black smoke out of it
Edited by pugrallye
Spiky
ok, will need to have a closer look at this when the engine comes :ph34r:
Spiky
DOH, sorry it was me being stupid, it is shown as connected to the VE- and i misread makes sense now :ph34r:
see below
Spiky
sorry to bring this up,
but i've got an order ready to buy these bits
see below
but i dont know what to order for the "R1"
anyone got any ideas?? preferably on www.rswww.com as thats down the road from me and i want to get them tomorrow :D
Spiky RS dont do counter sales, I tried on monday!!! they charge a fiver for postage but you get a fiver's worth of jiffy bags :D
if you hold on till midday tommorow ish I should have finished trying to fit my adapter to my 205.
Spiky
if i order and say pickup i can go pick them up, as told by the man in RS earlier :blush:
so i just need the part number for R1
my brother is an arse! they wouldnt let him do it apparently!
199-7135
minimum order qualtity;5
Mikey G
Spiky, i got a load of diodes and resistors the other week, i have more than enough to help you if you need any :D
Spiky
Spiky, i got a load of diodes and resistors the other week, i have more than enough to help you if you need any B)
cheers welshpug top man
mikey, i want to get them tomorrow, and for 3quid it wont be breaking the bank :blush:
but really appreciate the offer :D:o
smighall
I never got that to work. You can just alter the rev counter itself and it then works fine. Basically need to solder the input wire direct onto the chip rather than through the other stuff on the board. It's detailed on here somewhere.
Spiky
did you use 4 diode's? or 2 ( did you connect to 2 coils or 4?)
it's not much lost if it dont work, so not to worried
I tried to find that, but nobody's actually said where and how to do it sucesfully.
smighall
OK i'll try and find the thread.
But basically i haven't used any diodes at all, just a piece of wire soldered onto the back of the circuit board, taking the input directly to the input pin on the chip bypassing the other diodes on the rev counter's board.
so from the topic linked above, if I do this -
it'll work with MP3.1??
apologies for the size of the pic posted!
it did not work however, so I think someone's fibbing/withholding information...
Edited by welshpug
the method of an adapter works :) not sure if its reading 100% yet, does anyone know if the wattage or the zener diode affects anything?
smighall
That's exactly how mine is IIRC and it works spot on, are you sure you're taking the input from the correct wire out of the ecu?
yes! theres only 1 tacho wire!
pin 21 of my mp3.1 ecu
Edited by welshpug
Spiky
well how fooking cool am i :lol::DB):)
i have my rev counter working :D
15V Zener diode,BZX85C15 1.3W rs number 812500
1N4007-E3 rs number 6289546
ER74 silicone wirewound resistor,1K 2.5W rs number 1997135
soooooooooo happy, as i dont have to worry about fitting a shift light now, and can see what revs i'm driving at
funkymofo
I'd just like to say, thanks very much for posting all the part numbers etc..........makes it so much easier for an electrical dunce such as myself to know what to order!
Spiky
you will need to attach to all four coils remember :( not just 2 :P
also like to add, i'm always helpfuly, unlike some :P
Edited by Spiky
spot on matey :(
the 6 doesnt use wasted spark, and also drives the coils directly, so you just have to tag your adpter widget to the loom next to the ECU and connect the output to wire 112 instead of the ECU.
if its on a wasted spark and Igntion amp setup you only need 2 feeds, unless its a 4 coil app with separate outputs for each coil.
