Matt Holley
[trackday_prep] My 205 Gti6 Diary
Matt Holley
Before I go onto the latest engine I will give some background into my 205 :(
I bought this car in july 06 a week before rallyday at castle combe, it was a standard 1.9 with a magnex exhaust, it had a few faults but i worked on it every night for a week to get it ready for some track time at rally day, I didnt get much of a chance to test it out as it was very wet out :(
I then fitted some gti6 front brakes and did a quick service ready for a track session at trax, this went o.k till I came to the cool down lap and noticed the oil temp was off the scale and then the bottom end stated knocking :(
Not to be put off I went in to the demon tweeks stand and got a very good deal on some sparco pro2000 seats and harnesses :D
In november I bought an mi16 engine from anthony and fitted thet in december along with bbm group n engine mounts it all went well and after a few weeks it was back on the road :D
Over the christmas holidays I thought it was about time I fitted my seats
I then got a leak from the sunroof which flooded the passenger carpet so instead of drying it out I took it all out :D
I did a BAT day at castle combe but before that I fitted some spax shocks and spings, the car went really well and I had a great day :D
I still missed the torque of my old gti6 205 so when an engine came up for sale not to far from me I had to buy it, I also had a set of twin 45 dellortos to go on :D
So in the middle of march the mi16 was removed engine bay was cleaned up and while the engine was out I fitted a 406 master cylinder along with new brake lines, I also ran the rear lines through the car with a bias valve
Then it was time to fit the new engine before I did I replaced the timing belt, tensoiners and water pump and an mi16 clutch
Good clearence on the master cylinder
Now I always knew how I was going to fuel the engine but wasnt sure on the spark side, I eventually went with a kms ignition only ecu and a ford coil pack and leads, after a few problems with the kms mostly the fact it came with the wrong wiring diagrams and software I sent the car off to sandy and we dcided to go for a dta ignition only ecu instead and he also set the carbs up.
I also moved the battery to behind the passenger seat to get rid of a bit of weight from the front
So this is what the engine bay looks like today I am very pleased with it now I drove it back from cornwall yesterday 160 miles and I did another 50 today I just cant get enough of it :D
Current spec
ENGINE
Xsara vts (gti6) engine
New timing belt tensioners and water pump
Twin dellorto carbs and longman inlet manifold
ITG sausage air filter
Maniflow exhaust manifold into a magnex center and rear box
DTA ignition managment with a ford coil pack and leads
BBM group n engine mounts
1.9 be3 gearbox
Rally designs quick shift
BRAKES
283mm Gti6 front brakes with mintex 1144 pads
406 master cylinder
New copper lines run through the car with a tilton bias valve
BF goodridge hoses
Standard rear brakes
SUSPENSION
Spax adjustable front shocks with spax springs
E Tech strut brace
309 front arms and driveshafts (to be fitted)
309 rear beam (to be fitted)
Koni adjustable rear shocks (to be fitted)
WHEELS
1.9 wheels with goodyear eagle f1 tyres
EXTERIOR
Auto bonnet ( needs painting)
Roof plate still to be fitted
INTERIOR
Sparco pro 2000 seats
Sparco 4 point harness's
Momo steering wheel and boss
Battery relocated to behind the passenger seat
Edited by matt holley
t16ryan
Very nice :(:(:D:D
Matt Holley
Thanks I forgot to add I have also got working oil pressure gauge and light and water temp the only gauge I dont have working is the rev counter but I have a shift light for that :(
boldy205
nice one!! how have you mounted those bucket seats? are they on Sparco runners? and do they still tilt forward?
Matt.
Matt Holley
They are mounted on standard runners with the tilting bit removed
Very nice Matt! :(
Did you have to modify the sparco mounts to get them to bolt to the runners giving the right width? I see you have one turned round.
Matt Holley
Very nice Matt! :(
Yes I turned one round but other than that they lined up,that also gave it more room between the seats when I put them in the car :(
funkymofo
very nice indeed!
Glad there's a few threads kicking about like this, makes me motivated to get to work on mine!
What box are you using?
Matt Holley
very nice indeed!
1.9 box at the moment but I might change to an mi box if I can get one ;)
Guest Kernows16
Nice car, bet it sounds lush on the carbs :D
James_R
Looks nice any pics of the exhasut mani?
Bonzai
Did you do anything to fix the leak? Mine has got something similar although doesnt sound as bad,
Matt Holley
I have got some on my phone I will see if I can upload them, It looks like the one they do for the mi16 thought :D
Matt Holley
Do you mean from the exhaust? how did you know it was leaking :D
I did put it on the ramp yesterday and re seal it all :(
edthedrummer
Yes I turned one round but other than that they lined up,that also gave it more room between the seats when I put them in the car :D
so are you still able to use the tilting part of the original mount with them? I'm a bit of a newbie so any info on how or what you used would be appreciated.
Other than that, i really like the look of your car. Does relocating the battery make much difference?
Matt Holley
You probably could use the tilting bit but I just removed it, the seat would be higher up and I can only just get in with a helmet on as it is and I am 6ft.
I have not had much of a chance to test out the handling yet with the battery behind the seat but it has to be better to get a bit of weight off the front wheels :D
edthedrummer
Cheers.
I take it you just moved the battery there and used longer electrical cable to get to it?
Do you mean from the exhaust? how did you know it was leaking :)
I did put it on the ramp yesterday and re seal it all :)
I think Ben meant the water leak from the sunroof! :)
Matt Holley
O right :)
I removed the plastic trim from round the front of the sunroof and smeared some sealer round, it still leakes a bit but seems to have moved to the drivers side now :) I am fitting a plate to replace the sunroof soon so hopefully that will fix it :)
Matt Holley
Pics of the exhaust :)
tidypug
Very nice mate :).
Can you use the original exhaust manifold or do you need an aftermarket one like yours?
Matt Holley
Very nice mate :).
You can use the original gti6 exhaust manifold and it is very good but this came up for sale as a complete exhaust so I bought it as it was easier for me as I didnt have to mess around making a down pipe to fit the manifold etc.
Matt Holley
Next update
I fitted the 309 rear beam and koni rear shocks yesterday and I am really please with the result, it has made such a big improvement to the handling, it has to be my 2nd best mod so far ;):)
Pics for you :D
sonofsam
Really nice Matt ;)
Koni's and 309 beam is good isnt it :)
Matt Holley
Time for an update on the 205.
Much has been done since I last posted, I have fitted an omp 10 point cage and I aslo got hold of an mi16 gearbox with a quaife diff.
I also got round to getting the roof plate fitted and painted along with the bonnet :)
After a few track days the 1144 pads were cracking up and coming away from the backing and the discs didnt look to good either so I got some ds2500 pads and black diamond discs, they feel much better now :lol:
I am in the middle of fitting a new nissens rad and changing a few hoses ready for a track day at combe in december and I have some 309 bones and shafts to fit too :lol:
Here is the current spec
ENGINE AND GEARBOX
Facet red top fuel pump
Mi16 be3 gearbox with quaife atb diff
Group n gear rods
BRAKES
283mm Gti6 front brakes calipers
Black diamond 283mm drilled and grooved discs
Ferodo ds2500 pads
406 master cylinder
BF goodridge hoses
SUSPENSION
E Tech strut brace
309 rear beam
WHEELS
EXTERIOR
Auto bonnet )
Alloy roof plate
INTERIOR
OMP 10 point roll cage
